Picture not centered on Panasonic plasma TV. Right side of picture is running off screen - words on right edge are clipped. How can I adjust this?
  • nrandall Nov 16, 2008
    Same here.
  • Anonymous Apr 28, 2009
    same here.. anyone got this fixed?
  • 111 Answers
if this is under warranty still, i would take it to a service center or rma it to panasonic.. if it is not under warranty, you can try the following.
1) try a different video source and verify the problem is happening on all video sources and modes.
2.a) if the problem is not happening in all modes, remove and replace the cable that is causing the issue. if this doesn't remedy the problem, the controller for that particular input is going out
2.b) if the problem is happening in all modes, you can open the case and carefully disconnect and clean (de-oxit or rid-ox) the hirose style connectors on the back of the display panel.
3) disconnect and clean all ribbon cables around the display panel
this sounds like either the connectors are not performing adequately or are loose, the top ribbon is acting up for some reason, or the graphic controller is going out.
Posted on Nov 15, 2007
  • 1694 Answers
SOURCE: Blurry on one side of screen. Green and purple shadows
Convergence IC's should be replaced before any alignment is
attempted ....part # STK392-560....You need two......mount
to large heatsink...............T.
Posted on Dec 04, 2007
SOURCE: convergence
When this happens it means the convergance Ic's have failed ( STK392-110's) they will need replacing then the cross hairs will move again
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: philips 32pt television screen format off center, to the left
For me it was the cable box settings...
I'm not a tech person, so take this for what its worth. I had the same problem with my Vizio and my Time Warner Cable HD/DVR box using the HDMI cord connection. HD channels were always fine, and non HD channels were fine until I went to an HD channel and back. When switching back, the non-HD channels would be shifted to the left as you describe. After much back and forth with both Vizio and Time Warner (each saying its caused by the other), I stumbled across the following fix...
I went into the cable box (scientific atlanta 8300) "settings", under "display," under "output resolution." There was a list including 480i, 480p, 720p, 1080i, and "auto select." I unchecked both 480 options and left 720 and 1080 checked. Problem solved. The other "Display" menu settings are as follows: Picture Size = Stretch, Aspect Ratio = 16x9.
Hope this helps.
Posted on Oct 03, 2008
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
Posted on Sep 28, 2009
Th-50px75u right side of screen black
There are 2-3 z sustain boards at the bottom of the tv. reseat the ribbon cables first and ten if it does not change replace the board.
Apr 08, 2016 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Plasma TV not working properly
It sounds like your Plasma was dropped on the right side and some of the internal wires came lose from the circlet board. 1. Is Panasonic or Vendor willing to replace it; if not, I say go ahead and open it up and see if you can find the damaged circlet. 2. Easy way trash it and purchase a new one just not from the same vendor.
Jun 21, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Pillips Plasma - Screen is not centered.
Hi jasonlambert,
You can use the remote control to center the picture on screen. Press to the right of the round pad around the OK button until your image is centered. (I had the same problem once)
Jan 14, 2009 | Philips 42PF9630A 42 in. Plasma Television
Panasonic plasma
go in to your tv's menu and go in to picture settings , you either have the zoom function on or its been set on 4:3. check these and if zooms on turn it off or if 4:3 is on switch to 16:9
Nov 28, 2007 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Picture off center
If you were in the technician menu then look for the HCENTER adjustment (horizontal centering) then move accordingly.
Jan 31, 2007 | Hitachi 43FDX01B TV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
