Question about Wasp WWS500 Freedom Cordless Barcode Scanner Handheld Barcode Scanner
Can't enter pair code on wws500 - Wasp WWS500 Freedom Cordless Barcode Scanner Handheld Barcode Scanner
2 Suggested Answers
terry628
SOURCE: We have 2 WASP WWS500
Go to your blue tooth settings and delete it. After you delete it click on add blue tooth device. There is when it will ask you the 3 option's. The bottom Option is the one you want. (DON"T NEED A CODE OR DIDN"T COME WITH A CODE)
Posted on Sep 20, 2012
I have a samsung gusto sch-u365 and i want to pair it with the plantronics 240
In case you have never paired your headset to another phone before, just by turning it on, it should enter the pairing mode, denoted by its indicator light flashing alternately in red and blue. Otherwise, i.e. if it was paired to another phone before, press and hold the call control button until its indicator light flashes alternately in red and blue. Then, on your phone, press the left softkey and go to 'Menu > Settings > Bluetooth > Add New Device'. After a little while, your headset should appear on-screen. Using the directional key, select your headset and press 'Pair'. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is successful, your headset should enter the standby mode (blue light flashing every few seconds). There might be an indication on your phone screen that a bluetooth device is connected as well.
Hope it works for you.
By the way, in case any (or both) your headset and/or phone user guides happen to be missing, feel free to download them from here (headset) and/or here (phone).
Anyway, please, let me know if you need further informations.
Best regards,
Carlos
Jun 10, 2012 | Plantronics Explorer 240 Bluetooth Headset
Not able to pair my bt-03a with my android device
Have you already tried to put your headset in pairing (discoverable) mode first? Anyway, in order to do it, starting with it turned off, press and hold the 'Play' button for some 7 seconds, until the indicator light is alternately lit in blue and red. It is in pairing mode now. Then, withing a couple of minutes, on your phone, go to 'Menu > Settings > Wireless & network > Bluetooth'. If the bluetooth radio is not turned on, turn it on. Then, tap 'Scan for devices'. After a little while, your headset should appear on the phone' screen. Tap over it to make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is succesful, your headset should enter the stand-by mode. An indication that a heaset is connected should appear on your phone too. If your phone indicates that only phone calls are available, tap and hold over it, until a context menu comes up, and select 'media', in order to make streamed music ffrom your phone sound on the headset.
Regards,Carlos
Jan 20, 2012 | Genius BT-03A Bluetooth Headset
I am not able to pair my nokia bh-503 with my samsung galaxy ace. Please help me.
Try to put your headset in pairing mode first. Starting with it turned off, press and hold the multifunction key until the indicator light is flashing quickly in blue. Then, bring your phone and headset close to each other, and, on the phone, go to 'Menu > Settings > Wireless & network' and check the 'Bluetooth' checkbox. Then, tap 'Bluetooth settings > Scan for devices'. After a little while, your headset should appear on the bottom of the screen. Tap over it to make it pair. If a pairing code (or PIN or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is successful, your headset should enter the stand-by mode. It should appear in the paired devices list on your phone as connected. If you tap and hold over it and tap 'Options', you will be able to select your headset services.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please, let me know if I can assist you any further.
Regards, Carlos
Sep 14, 2011 | Nokia BH-503 Bluetooth Headset
Hello, I have charged the barcode scanner WASP WWS500 for at least 4 hours, as specified, but once I unplug it, I cannot seem to turn it on. (When it's charging, the green light is on) Help please...
Perhaps the battery has moved (due to a shock of the device) and is not connected (as it should be in the device).
Open the device and check that the battery is connected properly.
Then try to recharge.
Also, it's a good idea to remove the battery and test (with a voltometer) that it has some voltage.
Finally, if the battery was used for a long time or charged too often (without the battery being fully decharged), you might have to replace it.
If I were you, I would replace it with a stronger battery. according to specs, WWS500 have a 700mA battery, I would put a 100mA battery instead.
Aug 01, 2011 | Wasp WWS500 Freedom Cordless Barcode...
We have 2 WASP WWS500 wireless freedom scanners that we have been working great with desktop computers (we don't use a pairing pass code). We have just bought two tablet's (HP Touchpad) and would...
Jul 16, 2011 | Wasp WWS800 Handheld
Forgot blue ant defalt password
It is hardcoded to '0000' (four zeros). Anyway, put your car kit in pairing mode, prior to pairing it with your phone. If it has never been paired to another device before, just by turning it on (i.e. pressing and releasing the microphone shaft), it will enter the pairing mode, denoted by the indicator light flashing alternately in red and blue, right away. In case it has been paired before, or, rather, it refuses to enter that mode automatically, you must force it into that mode, by pressing and holding the accept button whist turning it on. Anyway, once in pairing mode, make your phone's bluetooth application search for new devices. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards,
Carlos
Jun 17, 2011 | Blueant Supertooth Light Bluetooth Speaker...
I have problem pairing the device with my LG VX8300. It is turned on and flashing but cannot be found in the search. I have also entered the 0000 code
Try to put your headset in pairing mode, prior to trying to pair it with your phone. If it has never been paired with another device defore, just by turning it on, it should enter that mode, denoted by its indicator light being steadily lit in blue. Otherwise, turn your headset off. Then, press and hold the Muiti-Function Button for far more seconds than the time required to turn it on, until its indicator light is steadily lit in blue. Then, within the next couple of minutes, bring your phone and headset close to each other, and make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make your phone connect to it. If a pairing code (or PIN, or passcode) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. There should be an indication on your phone too, that the pairing process has been successful. Otherwise, turn you headset off and repeat the pairing process all over again.
Hope you are able to sort your problems out soon. Anyway, please, let me know if I can help you any further.
By the way, if your headset's quick start guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Jun 13, 2011 | Samsung WEP460 Bluetooth Headset
Passkey to connect to samsung Freeform II.
When prompted for the password, enter 0000 and this will allow the headset to successfully pair with your phone.When pairing is successful, the indicator on your headset flashes blue. Your headset is now connected and ready to use.Hope you are satisfied with my solution.If you need further assistance please post me a reply.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 13, 2011 | Plantronics Hama Voyager 520 Bluetooth...
I cannot pair a Nokia 6700 with Samsung Galaxy s11 via Bluetooth. The Galaxy recognises the Nokia, but says problem with PIN nunber or Password. I don't know of any such PIN or Password. Cannot connect...
If you need the pairing code for Bluetooth to connect just pairing with the same code in each device
for example if your device asking for code just enter 1 in your device ( Samsung galaxy) and enter the same code (it means 1 for Nokia), the code will depend on you but the important the code must be same each other.
Jun 05, 2011 | Samsung Cell Phones
HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
Jan 30, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Wasp WWS500 Freedom Cordless Barcode Scanner Handheld Barcode Scanner Logo
852 people viewed this question
Top Wasp Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jude24
Andrew Taylor
Andrew Taylor
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
