Error message "close back
    Master:
  • 395 Answers
You will need to shutdown, (unplug fax machine), open back and close tightly again until you hear a click sound turn it back machine again. It should work. Most of time, it is not securely closed. Thanks
Posted on May 19, 2011
  • tara fonteyn Dec 06, 2011
    the back cover is closed, I turned it off, unplugged it, same result. The only thing that happened before I had same problem, is a paper jam. Still won't clear message
My nikon D-80's flash won't pop up, yet it also won't go past the flash sync speed of 1/200 while flash is down
Was the camera impacted? Sound like the flash up switch if always closed. Remove battery. If you carefully remove the flash cover (two screw underneath) by first inserting a business card under the flash on the rewind side (yeah, we haven't come up with a better term!) at the back and slide it forward freeing the flash down latch), and do not touch the flash tube as there is 300 + volts across it if it is charged!
Look at the pivot for the flash on the release button side at the back, you will see a small switch. the top part may be under the activating rod - reset it above the rod and it will now work properly
Once again, be careful - there are 300 volts across the flash tube if it is charged
May 06, 2012 | Nikon D80 Digital Camera with 18-135mm...
Unable to close Cover E of Fuji Xerox c525a
For anyone smashing their head against the wall about this problem I finally found out what the issue is in regards to the C525A Cover E not closing.
If you run into this issue you need to look inside the printer where Cover E is, at the very bottom of this is a piece which looks like the rest of the printer but actually freely moves up and down on a swivel. Put it in the up position and as you go to close it it'll fall down again but this time Cover E will close. Not banging it shut or punching it, it all clicks back into place nicely.
Nov 19, 2011 | Xerox DocuPrint C525A Laser Printer
My Toshiba e-studio 233 copier is giving the error message, "Close side cover." Opening any cover to close again changes the message to "Close x" where x is the part opened, until that...
there is a switch at the side that is being push by the cover when it closes check this switch to be sure it hits the button when close or you may replace the switch it has a problem.
Jun 27, 2011 | Office Equipment & Supplies
I have a Toshiba estudio 202L copier. It has been working fine. When I turn it on, I hear it turning on like usual and see the light come on under the paper tray, there are no error messages, display...
try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Jun 14, 2011 | Toshiba e-Studio 202L Copier
Canon MP830 printer giving error message "inner
If the inner cover is open when starting normal printing,close it before pressing [OK] on the machine.Do not open or close the inner cover when printing.This may damage the machine.
Jun 02, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Brothers Printer MFC 7420 Error Message "Back Door Open" I opened it and closed it several times still getting message. I unpluged it andtried again. Help
Hi. You have to follow these steps: Be very careful:
1. Open front cover, like in this image:
2. Pull out your printer's toner cartridge & drum unit:
3. Open back cover
4. Pull the tab which is in front of you in order to open the rear chute cover.
5. If there is any, pull the jammed paper out of the fuser.
6. Close back cover and put the cartridge toner & drum unit back where it belongs.
7. Close front cover too and see if it works! If your error will still appear, try powering your printer OFF & ON
I hope I helped you!
May 20, 2011 | Office Equipment & Supplies
My Brother MFC-8680dn keeps giving me a "Print Unable 72" error message. Any ideas how to fix?
According to Brother Solution Center:
The machine may not work properly because of the condensation inside of the machine caused by a temperature differential between the inside and the outside of the machine.
To clear the error message please follow the steps below:
  1. Keep the machine's power on and open the front cover.
  2. Leave the front cover open for 30 minutes.
  3. Close the front cover.
  4. Turn off the machine's power switch and turn it on again.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Brother Office Equipment & Supplies
HP officejet copy machine. 7210 keeps beeping and flashing message (very quickly) "Close door" Doesn't appear any doors are open. Copier works but keeps making beeping sound!
Could be one of two things. Either there is a door or cover you are overlooking (very easy to do), or there is a switch actuator that either needs adjusting, or replacing. Try opening every cover and door you can find, and taking out the photoconductor unit, unplug it, and give it a good looking over (front, back, inside). Put photoconductor/toner unit back in, and close all covers FIRMLY. This is where I would start if it were me. Hope some of this helps!!!
chad
Oct 08, 2008 | Office Equipment & Supplies
Brother MFC 7820N error message "back cover open" but cover is closed. machine is now not functional as error message can't be removed
If you open the back cover (depress the release button on the top right) If you lift it up look for two black anchors that grab the base when you close the lid. I have one that has a broken tab on the left side, which happens to be the same side as the cover closed switch. If the top is not closed all the way the rollers do not line up and the cover switch is not depressed to let normal operation. Also, if the switch arm is busted (case colored plastic push pin protruding from the cover) it will not make contact with the switch when closed. Try closing the cover and push down on left side of the fax. Does the error go away? If not, the actuator arm or the switch are bad.
James
Apr 06, 2008 | Office Equipment & Supplies
Fax fixable? error msg
We call the moose method of clearing paper jams, the RCMP method, cuz they only know how to shoot to kill. You did good. Except, there is no such thing as "Bending" anything. The term is "re-form."
Dec 21, 2007 | Brother IntelliFax-2820 Laser Fax
60 people viewed this question
jasbo
jasbo
