Question about Sharp XR-1S Multimedia Projector
Screen lopsided My screen projection is lopsided. I have tried to use the menu options to adjust the screen but it does not help. The screen projects like a trapezoid. When I turn the unit off, I can see the lens and a small cover @ the bottom. This cover is not level, it tilts to one side. I am assuming this is the root and cause of my lopsided projection. Solutions???
2 Suggested Answers
omtronixom
  • 172 Answers
SOURCE: cleaning the lens of a xv-s96u
Open lamp cover and out bulb.Use air blower.It need service
Posted on Mar 03, 2010
I cannot adjust the # 1 and 2 + to line up in my color convergence. The green one is lopsided and too far down on my JVC 56 inch AV56Wp30
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 10, 2011 | JVC AV-56WP30 56" Rear Projection...
How do you access the convergence calibration menu on a RCA P52926 Rear Projection TV
Hello
To access the convergence calibration:
Press the MENU button on the remote.
2. Press 3 to select the Screen option.
3. Press 4 to select the Adjust Projection TV option.
4. Press 4 to select the Advanced Convergence option (the
Advanced Convergence screen appears).
The green pattern is fixed. The red and blue patterns are adjusted to
the green pattern. The Red Convergence appears first by default.
5. Colored cross-hairs show the current adjustment position on the
grid. To move the cross-hairs to a different position, use the
CH+/- buttons on the remote to move the cross-hair highlight up
and down, and the VOL+/- buttons to move it right and left.
6. Use the arrow buttons to adjust the red pattern. Each press of
the arrow button makes a slight adjustment from the center of
the cross-hairs - you can press and hold the desired arrow
button to make a faster adjustment, and then make fine
adjustments with single presses of the arrow button.
7. Press the INFO button to switch to Blue convergence and follow
the steps above to adjust the blue pattern.
8. Press OK to exit. You will be asked if you want to save the
adjustments
Yes Saves adjustments.
No Returns to the Advanced Convergence screen allowing
further adjustments.
Clear Exits screen without making any changes
Note: Before you use the advanced convergence feature, you must
complete the previous steps to align the tubes
May 19, 2011 | RCA P52926 52" Rear Projection Television
How do i adjust convergence on a 55 inch toshiba
You need an original working Toshiba remote: two choices here--in the customer menu there will be an option for this and there is a hidden tech menu for finer adjustment all over the screen.
Usually the customer mode works ok--if you find red or blue will not adjust somewhere you have a problem-that aside tell me what you are trying to acheive?
SD TECH
Dec 12, 2009 | Toshiba 55HX70 55" Rear Projection...
I cant adjust my picture size to normal on my Sony Wega 51" TV
the screen size feature is gray out because there is a previous option selected already and computer assumes you want always that size.So going into the menu and try to look for a previous selection related with: "screen size default". The menu allows you to selec this option and (i like to "standard" and i adjust screen size with my cable box feature who allows change size also if is needed, but now days cable box change it itself because is automatic) is install in the original program by manufacture because helps you to keep one size and you don't have to change it any moment. This default option is outside the regular screen size option, if i remember right is in set up screen. try to find this options in your user's manual to follow the right screen procedure..
Apr 21, 2009 | Sony KP-51WS520 51" Rear Projection...
Someone changed a setting
The setting is in the Menu. It sounds like you went to the "Image" section which lets you make the adjustments you list. Try the "Source" menu, then "Mirror". That's where you will find options for Rear Screen Projection, which makes the image backwards.
Feb 05, 2009 | BenQ MP610 Multimedia Projector
Need to adjust convergence
this is a very nice tv very strong, but you have a problem on the convergence circuit or more likely on the power circuit for the convergence and this is the reason why the main processor it doesn't recognize this circuit. it need service not a mayor problem.
Nov 25, 2008 | RCA P52926 52" Rear Projection Television
Convergence/menu problem
The convergence power supply has failed,replacing the 215530 reg.on this board will restore the convergence menu,this board is on the right side facing the back or the set mounted on the black plastic above the board with the 6 heat sinks on it
Mar 01, 2007 | RCA P52930BL 52" Rear Projection...
Adjusting convergence
try unplugging and waiting over night and then repluging it in this will reset the computer
Feb 20, 2007 | RCA P52928 52" Rear Projection Television
RCA P52929
go to the menu select the screen option 3 and then select option 6 . adjust projection tv. green is for green use it first then adjust the red and blue until the patterns on the tv screeen appear white.
Sep 26, 2006 | RCA P52929 52" Rear Projection Television
Menu (SCREEN) #4 Adjusting projection is gone
you have a convergence problem and this can only be serviced by a tech with the know how to service the rca projections sets as there are many alignments in this set and some are manual driven but mosrt are on screen driven. You need the know how to get into the service mode. Sorry my friend but my recomendations would be to send this set out for service.
Jun 08, 2006 | RCA P56812BL 56" Rear Projection...
Sharp XR-1S Multimedia Projector Logo
273 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
