Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I recently bought a 2002 craftsman 17.5 hp, 42" cut deck mower.(Mdl# 917272670) It hesitates after you turn the key to start. When I turn the key to start position, choke on, you hear an initial click, than nothing for 2-3 seconds, than it starts to turn over. I just put a new battery in, but it did not solve the problem. also when I engage the cutting deck, than dis-engage them, the blades continue to turn. (stay engaged) thinking about replacing the belt. Any suggestions?
    President:
  • Craftsman Master
  • 1,545 Answers
Your starting problems sounds just like the overhead valves need to be adjusted. They work in timing with the compression release feature in the engine and when set to specs enable the engine to start much easier. You remove the 4 screws in the valve cover and then with a metal feeler gauge check the gap between the rocker arms and the valve's ends.This being done after you remove the spark plug, turn the engine by hand until it comes up on the compression stroke and then 1/4" down into the power stroke, you hold it there and adjust the valve lash. I have the same machine and a new battery spins the engine quite well. Try the valve adjustment.
For you engage/disengage problem, check the action of the engagement lever behind the "dashboard" area and under the mower. The linkage to the lever needs to be checked and possibly lubicated if no foreign matter is jamming it's movement.
Posted on May 19, 2011
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Murray 42 in 17 hp doesnt start
i would look at the safety switches that being the most common cause
Jun 16, 2012 | Garden
I purchased a used Craftsman LT 1000 17 hp 42"
I've had to do this at least 5 times. If you look under the body, there are two supports that carry the mower deck and lift and lower it. Each of these has a nut that holds up the deck and the nut is on a stud that goes up and down when you raise or lower the lever. Put the deck in the middle of it's range, around #3, make sure the key is off, move your blades so they are on the right and left edge of the deck.
Get yourself a device to measure blade to ground height, I have a block of wood that is 3 inches long. Make sure your floor or ground is level and tires are properly pumped up. Then raise or lower the adjustment nuts until both sides are equal height.
Gary
Jun 14, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
We need the electrical diagram for a 17 HP Craftsman 42" cut riding mower. Model-311707 Type-0321-E1
this is as close as i can find.. take a look and see if you can use this diagram...good luck. go to page numbers 34 and 35
http://www.hammerwall.com/Download_Manual/18200/
Apr 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need the battery size for a 2005 21hp 42" cut craftsman rider
Most Lawn and Garden batteries are the came size, if you are referring to amp rating I like to go on the larger side I believe you can get between 175 to 425 cca (cold cranking amp) batteries. On a 21 hp I like to stay no lower than 275. I have tried lower amp batteries and sometimes on start I get a hesitation.
Mar 17, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
158 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
