Question about Simplicity Serge Pro SW432 Mechanical Sewing Machine
How do you lengthen stitch. The stitches are so close together it looks like a satin stitch. I have no manual for it. thanks!
  • Simplicity Master
  • 1,129 Answers
Your machine should have a stitch length dial on the right hand side above the flywheel, it might have numbers from 0.5 to 3 or 4, higher number for longer stitch (effectively this moves the foot and feed dogs faster in relation to the needles to make the stitch longer).
If you have the Serge Pro SW432 that your enquiry is linked to and you have not used a serger before, then definitely get hold of the manual, you will need it. Sergers are very different to sewing machines - once you've mastered one, its easy, but there is a learning curve.
Firstly, ALWAYS extend the thread aerial up, you'll see loads of images of sergers sitting nicely with the aerial in the lowered position, great for moving them to avoid damage. But they won't work well, a serger seams at 1500 stitches per minute and the thread streams off the cones so you need to ensure there is a good clear feed via the aerial to the tension dials.
Buy good quality thread cones and keep it out of the sun and dust. Cover your machine when not in use (lower the aerial first). You could start with white, grey and black thread as this will cover a lot of fabric prints/colours etc. To change thread colour, you will need to cut and knot on the new thread for the two loopers (right hand side cones) - do this about 6 inches above the first thread guide, and then chain off to feed these through down to the needle plate, when you see the new colour come through okay, stop. Repeat the process for the needle thread or threads (3 or 4 thead depending on what stitch you are sewing) but stop chaining when the thread knot is above the needles. Stop, loosen these tension dials and pull the thread down, cut out the knot with scissors and thread the new colour through the two needles. Use threading wires if you have them, or tweezers. Pull both these and the two looper threads together under the pressure foot, lower the foot, turn your tension dials back to 5 and chain off. The thread sequence is important, mostly top looper, bottom looper, then needles, this is so much easier demonstrated than explained.
If you can find a classroom/shop offering overlocking user lessons, go take a couple, its well worth the money. Otherwise go to you-tube and watch all the videos you can search on sergers, threading, etc.
Good luck with your serger, please respond with 4 thumbs if this has been helpful to you. :-)
Posted on May 19, 2011
I have been given my mothers singer ultralock 300 electronic .but there was no user manual with it I can not find a serial no on the machine to order one on line.please could you help me. thanks s e winter
Posted on May 23, 2011
  • Tally Girl
    Tally Girl May 25, 2011
    try www.singerco.com go to customer suport/ manuals, if its availble, they will have it there, either as a download or purchase it.
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
How do i widen buttonhole stitches to make larger buttonholes?
Stop using the button hole program ! Use the button hole foot but do the stitch by hand adjusted satin stich ! Remember to lock off after each rib sewn !
Aug 27, 2014 | Sewing Machines
Stitch length for zig zag satin binding 8mm equals what number?
Neat zigzag stitches are usually achieved at "2.5" or below.
Closed up zigzag stitches (close together) are referred to as a
satin stitch its likely you will want to set for 1.5 or at most 2. http://www.searspartsdirect.com/partsdirect/user-manuals/3116-singer-parts-SEWING+MACHINE-manual Look for page 40 in the owners book or scroll down and if you see numbers not on the page but on the scroll bar look for 47. It has some great pitures that can help you out.
May 13, 2014 | Singer 3116 Simple
Bernina buttonhole 730
Use your ruler and measure your button. Then transfer those measurements to your garment.
Use chalk to mark the center cut line of your button hole. Mark the end or stop point of the button hole per the measurement.
Practice on a scrap of the same fabric before you begin on your garment.
Set your machine the satin stitch zig zag at a fairly narrow width.
Begin satin on one side of the center line of the mark. Slowly stitch down that side until you get to the end. STOP. Widen your satin stitch to the max. sew about 1/8" and stop with the needle down on the opposite side to your first line of stitching. Turn the fabric, narrow the stitch to match original satin stitch. Sew slowly down the other side of the center mark. STOP, lengthen the stitch, sew 1/8" then do a couple back stitches.
That's one way. Another older way is to sew 2 or tree straight stitch lines around the center line. Remove then use a hand rendered button hole stitch after you cut the hole.
Oct 27, 2013 | Husqvarna Sewing Machines
I want a loose button-hole type of stitch to do my first applique by machine. I have put the needle to one side, put on foot #20 -- and now what stitch?
This depends entirely on your model of machine and the kinds of stitches it is designed to make. Not all machines will make the kind of stitch you describe. My machine has a buttonhole stitch, but with slanted bars, and it really doesn't give the right look.
Check your machine manual and look for a stitch that gives you the look you want--you might have a "blanket stitch" option. If your machine doesn't offer a buttonhole or blanket stitch that gives you the look you want, you may want do use a narrow zigzag satin-stitch. You can also do a straight stitch very close to the raw edge of a fused applique but it won't look as tidy.
Apr 01, 2011 | Sewing Machines
Buttonhole making instructions from the manual of the Singer Simple do not seem to be accurate. The tension is incorrect and the machine is only sewing down one side without creating the satin stitch/...
Some machines will start out by sewing a straight stitch all the way around the buttonhole area first and then will zigzag/satin stitch along the sides. Bar tacks will be the last stitches sewn - hope this helps!
Nov 09, 2009 | Singer 3116 Simple
Lengthening stitches.
You can adjust the length of the Zigzag (Satin)
Stitch using the buttonhole fine-adjusting screw. You will find it right above your stitch selection dial.
> For a longer stitch length, turn the
buttonhole fine-adjusting screw with a large
screwdriver in the + direction.
> For a shorter stitch length, turn the
screwdriver in the - direction.
Hope this helps
Apr 06, 2009 | Brother XL-2230 Mechanical Sewing Machine
Simplicity Serge Pro SW432 Mechanical Sewing Machine Logo
299 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
