Question about Surebonder High Temperature Glue Gun
Surebond mini won't push the glue stick forward. it heats and if i push the glue stick forward by hand the glue comes out, . the trigger won't push the stick.
    Champion:
    New Friend:
  • 217 Answers
You can try to unscrew the plastic casing panels and see if the spring the regulates the trigger needs to be recalibrated
Posted on Feb 26, 2013
3 Suggested Answers
  • 12 Answers
SOURCE: Arrow TR 550 heats up fine but glue stick won't
The trigger probably really is slipping on the glue stick. If you've changed the type or size of glue recently, try changing back to what you were using, or just something else. Maybe the glue stick is too small, or too slippery for the gun. If not that, then it's a mechanical problem. There are some screws on the side of the gun. With it unplugged and cool, take them out and open the case. It might be stuck together with some internal connections as well as the screws, but jamming a flathead screwdriver in them can usually wedge them apart. With the gun open, move the trigger and look for the parts that move with it in the area where the glue stick goes. If you can find something to attach to these parts to make them just a tiny bit longer, do that. The parts that grip the glue have probably worn down or just don't fit, and the fact that you can tell the trigger is slipping means that it's probably very close to grabbing, but not quite close enough. Any little extension to the grabbing parts should do, but be careful not to block the path of the glue.
Posted on Mar 01, 2011
krb55
  • 604 Answers
SOURCE: I have a new Surebonder
it sound like the charge ran down, recharable glue guns are not typically recomended for large project becuase heating elements run down batteries very quickly. to get the stick out of your gun, you will need to fully charge it and then after that turn it on and when its warm pull the trigger and the glue should once again come out, For large project I would recommend you purchase a wired (plug in the wall) type glue gun. Thanks for you question
Posted on Mar 22, 2011
Trigger is sticken
Glue guns are made mostly out of plastic, and are really not made to be repaired.
May 10, 2015 | Crafts & Hobbies
Need the instruction manual for a Stanley GR100 glue gun
I do not believe there is a manual. there are instructions on the package. Insert the glue stick and turn on the gun. When the glue melts and the trigger moves glue will come out the front tip. This model has 2 temperatures so if it delivers too fast or runny you can lower the temperature. You pull the trigger to push the glue stick into the heating element to melt the glue. It is pretty straight forward. As the glue stick is consumed you stick in another glue stick. I suggest testing on something before using on your project. Do be careful of the hot end. It will definitely burn you if you touch it and the glue coming out is nearly as hot as the metal.
Jan 17, 2014 | Stanley Gr100 Glue-pro Dualmelt Glue Gun
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
How does a glue gun work?
A hot glue gun is a very useful tool for joining modelling materials and even more substantial materials can be fixed together with it. 'Sticks' of solid glue are pushed into the back of the gun, the trigger is pressed pushing the glue stick forward and molten glue comes out of the nozzle. The glue is manufactured from thermoplastics.
You can check out this site for more info:
Jan 10, 2013 | Crafts & Hobbies
I bought a Surebonder Fine Tip Hot Glue gun (small, for crafting) about less than 2 months back. It was fine at first until it stopped squirting melted glue and i had to manually push the glue stick from...
My guess is that you left the gun plugged in too long for the amount of glue that you were using. If you are using it for a good squirt every minute or so, you can leave it plugged in, but if your leave it plugged in too long while using too little, then the heat works it's way back up toward the back of the glue stick. First thing that happens is the glue-advancing trigger stops working because the advancing mechanism can't push against the softened glue stick. Leave it run even longer and it melts further back. Then when you turn it off it cools, but the melted glue is now in places it shouldn't be. If you take it apart you might be able to scrape and pry all of the once-melted glue out of it, then you would be back in business. Good luck!
Aug 27, 2012 | Crafts & Hobbies
How to use sterling mini glue gun
you get what you pay for, i hope you can learn to use it well!
Dec 26, 2011 | Crafts & Hobbies
I have a new Surebonder rechargeable glue gun. I was gluing a large pc. and rushed to get another stick and it would not feed by pulling the trigger, There was one glue stick (partial) still in gun, but...
Mar 22, 2011 | Crafts & Hobbies
Arrow TR 550 heats up fine but glue stick won't feed by the trigger. If I push the stick with my hand glue does come out, but the trigger seems to "slip" on the glue stick. Any ideas?
Feb 28, 2011 | Heavy Duty Arrow Pro Glue Gun Tr550
Dear Experts, I need assistance from you ppl.I stay in India. I bought a medium quality glue gun and a glue stick. I plugged the gun to the power socket(220v)and waited for the glue to come out of the...
It takes a couple of minutes for the gun to heat up. When you first plug it in, touch the metal nozzle with your hand. It should become obviously hot within 15 seconds and too hot to touch within a minute . After it fully heats up (a couple of minutes), squeezing the trigger should advance the glue stick and push molten glue out of the nozzle. However, there is often an initial resistance to the trigger and you may have to squeeze a bit hard to get it started. If there is a problem with the trigger mechanism, you can also advance the glue by pushing directly on the back end of the glue stick with your thumb. Good luck.
Aug 04, 2010 | Garden
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Aug 27, 2008 | Dremel 1550:30 Versatip Tool Kit
Surebonder High Temperature Glue Gun Logo
247 people viewed this question
Top Surebonder Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Surebonder Craft and Hobby Expert? Answer questions, earn points and help others
