Question about Smeg FAB40PS Top Freezer Refrigerator
How do I defrost freezer compartment without switching off fridge
    Sergeant:
    Champion:
  • 257 Answers
There should be a hole behind the temp controls in the refrigerator top, you insert a large flat head screw driver in there and turn until you hear a click, then you will hear the fan stop, This is defrost mode. It will advance on it's own if everything is working properly. Tip: Hold the screw driver even and flat to make contact with both edges of the slot when turning.
Posted on May 19, 2011
Where is the defrost timer in a Zanussi ZNB323W/ Electrolux/ ZNB323S fridge-freezer ? I can't find it?
The timer box is located in the compressor compartment to connect the timer to the electrical components which
defrost the battery evaporator (defrosting heater, thermal switches).
Dado
Sep 24, 2015 | Zanussi & Electrolux Fridge Freezer Handle...
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Fridge and freezer stopped working but fridge light still on should the orange switch by the light be on or off don't know if that is the defrost button
Sounds like a motherboard or defrost control board. Can you tell me the model number found inside the fresh food compartment or around fresh food section door frame, Without the model number it is hard to guess what the switch is that you are asking about, Thanks Sea Breeze
Dec 08, 2012 | Refrigerators
Fan in freezer is making a real bad sound...... griding like it may be struggling to to stay running
This can be caused by frost accumulation on or aroundthe freezer fan Icing . And due to this no cooling will be in fridge compartment.
Unplug power and . defrost it. And after some times, switch on fridge.
This is due to auto defrost switch malfunction. keep temp setting at 5 degree and check auto defrost (if your fridge having that option) is working. If not you have to replace PCB. Thanks.
Jan 28, 2011 | Maytag Admiral Top-Freezer Refrigerator
FREEZER IS FINE. FRIDGE STILL NOT COOLING
it sounds like your circulation fan is not working. it is located in the freezer compartment in front of the evaporator or very close to it. you should hear running either all the time except in the defrost cycle. on some models the fan will shut down when you open the freezer door and restart when you close it. if the fan is OK you have a problem in your defrost circuit. probably a bad heating element or a bad defrost cutout switch or bad connections in the freezer compartment. sometimes the defrost timer can go bad but not often. I have found in my experience that the problem is usually the other two components I mentioned or bad connections.
Mar 13, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
Smeg FAB40PS Top Freezer Refrigerator Logo
219 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Charles T Nevin
Charles T Nevin
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
