Updates my automatic updates dont instal
When I finally installed Internet Explorer 8, I was reallyfrustrated when I tried to do a Microsoft Update (or Windows Update) as I fellinto an infinite loop of checking for updates. It would continually spit meback out to the 'getting started page' and then try to update my Active X andthen give me a “Check for Updates” button, over and over. I found the solution, and here is what I did:
Apparently, you need to reset the Windows Update Agent. In my case, a previous update was inhibiting the re-install of this “agent” so I had to force it to re-install. Here is how:
  1. Download and install the Windows Update agent. Go to http://support.microsoft.com/kb/949104
  2. For me I downloaded to my desktop the “For an x86-based computer” windowsupdateagent30-x86.exe
  3. Once downloaded, Click Start, click Run, click Browse, locate the file that you saved and then click Open.
  4. Make sure the whole path is in quotes and add the /wuforce switch to the end of the location, and then click OK. It should look like this:
    "C:Documents and SettingsjoeblowDesktopwindowsupdateagent30-x86.exe" /wuforce
  5. Click Run.
  6. Follow the steps to complete the wizard.
  7. Restart Internet Explorer
***Important *** If you have attempted this once before, and you with to try again to reinstall Windows Update Agent, download the relevant file from one of the links on the Microsoft kb site above and save it to a drive where Windows is not loaded. This is because the file cannot be launched directly from the system root directory. Click Start, click Run, type: "D:WindowsUpdateAgent30-x86.exe /wuforce" (without quotations) and then press Enter to install the Windows Update engine. Note: There is a space between "D:WindowsUpdateAgent30-x86.exe" and "/wuforce" D: is the drive where Windows is not installed (ie a flash drive or a 2nd hard drive etc)
Posted on Oct 22, 2009
Everytime I do a windows update, it either crashes or hangs on "shutting down" (after leaving it on all night!). Then I lose everything. Help!
you have to be more spacific on what you are doing and what os you are using. Are you using Windows 7 or Vista. If you are using vista, Dont. upgrade to windows 7, it's worth it. but everything else aside, try different ways of installing the updates. you can download the updates manually and install them other then just letting automatic updates do everything.
May 09, 2011 | Acer Extensa EX4420-5239 Notebook
I download my own copy of windows 7 (32bit) but i dont know what drivers i need to improve't ,,,
You shouldn't have problems installing the drivers for your Toshiba Satellite A6653DV Notebook as Windows 7 should be able to install the drivers for your devices automatically. If not, you can always go to "Device Manager" and right click the device you like to install then use the option for "Update Driver Software" then "Search Automatically for updated drivers". Make sure that you are connected to the internet when doing this so windows can search of an updated driver for your device.
Hope this helps.
Apr 18, 2011 | Toshiba Satellite A6653DV (PSAW3U042001)...
Windows automatic updates where installed and i dont need most of them. How do i find out whitch ones i need to uninstall? its causeing problems with my intel
You can check for all installed update under Control panel - Programs and Features - View Installe Updates on left side panel ( for VISTA and and Win 7 )
In XP check under Add/remove programs in control panel.
You can uninstall them by selecting the one you dont want in your pc and click uninstall
Turn Off the Automatic Windows Update from Control panel - Windows Update
Jun 19, 2010 | Computers & Internet
I dont no how to get to my windows update to see if i am running on sp3 i had gotten advice to check if i was but i dont no wat to do. i had tried to see if i could find t and i had searched for it witi...
Hi friend,
You don't need to find window update.you just need to on you automatic update option. you need to follow following step..
Open control panel ......then...click on automatic update....then..check automatic check button.....
then system will find new updates your window..
Dec 24, 2009 | Microsoft Windows XP Home Edition
I had updated my phone software today but while installing the could not restart for that reason i removed data cable,now it cannot get start
oh this the major problem. the company srictly advises you dont remove the usb cable while updating the software.. otherwise the phone will corrupted. Next time dont remove Usb cable while Updating the software. the phone restarts automatically while updation. its a common factor......
Nov 04, 2009 | Nokia 5220 XpressMusic Cellular Phone
Updates not installed on computer
Please go to add/remove from setting in control panel.See whether the application is listed over ther.If you don't want that application any more, remove it from there.
Aug 08, 2009 | Computers & Internet
How do I delete certain music from my iPod Nano 4gb
first to delete a song from your computer you must have itunes installed the software on your computer. connect your ipod to computer via usb cable. then it will and should automatically update it and do an update. After the update go to the songs on your itunes it updated and uncheck the songs you dont want on your library playlist. disconnect your ipod and close out of itunes. connect your ipod via usb cable back to your computer and open itunes if it doesnt automatically. then it will update the songs that were on it and not the unchecked ones you dont want deleting them. glad to be of service. thanks!
Jun 08, 2009 | Apple iPod nano
Update problem setting
vista has tons of updates problems, just try to catch it when you can, most fail any way
Apr 17, 2009 | Averatec D1002UHCE-1 All-In-One Intel...
Windows XP home edition service pack 3
OK, do you wish to install further updates? if you dont, then what you can do is disable automatic updates
To do this, then right click on the desktop the icon My pc and select properties. The sub menu Automatic Updates you will find on the top, click that and check the box disable automatic updates
Some Automatic updates are dangerous and can cause your computer to stop working correctly. I would recommend you disable them. Once this is disabled, restart your computer and the access denied messages will disappear. This is because its most likely you have automatic updates set to download and install automatically. But once you disable this, problem should be solved.
If you have any more questions, please let me know
Oct 16, 2008 | Microsoft Windows XP Home Edition
Help!
You might have connected to interent and your windows updates are automatically downloaded. You need to install those updates. Actually it did not shut but power goes off may be it was on stand by mode. Now shut down (press Alt+F4) your laptop from menu. Choose Install Updates and Shut Down from the drop down list.
Now it will install updates and after completion it will automatically shut down your laptop. Hope it works
Feb 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
91 people viewed this question
David Payne
David Payne
