Question about Cycling
The chain came off and it appears that a part might have broken off. Would like a picture or diagram of what it is supposed to look like.
    Brigadier General:
  • 8,546 Answers
Timming chain has play in it wont crank
your timing chain tensioner is loose, or broken. Its not good to run the truck like that. If the timing chain is sloppy, the motor is not in rythum spark plugs ignite when the are not supposed too etc. Good luck, if your changing it yourself, I can walk you through the proceedure
Jan 19, 2013 | 1996 Chevrolet Blazer
5-disk autochanger
This product manual should be able to guide you in the reinstallation of this piece.
Jun 02, 2008 | JVC THC5 Home Theater System with 5-Disc...
How wiring diagram for christmas lights work
All the bulbs in a section of lights are connected in series, meaning one after the other, like links in a chain. If one bulb goes out the chain is broken and that section goes out. All modern light sets have bulbs which have a built-in feature called a shunt. The shunt in the bulb is supposed to short out if the bulb filament burns out. The advertising wording would be something like 'if one bulb burns out, the others stay lit'. It usually works, but there are limits. Sometimes the shunt in the burned-out bulb fails to work and the chain remains broken. You have to find the bad bulb and replace it. Also, every time a bulb burns out, if the shunt is working and the other bulbs stay on, the power to each remaining lit bulb increases. This puts a strain on the remaining bulbs, which is why you should always replace burned out bulbs as soon as you discover them. If you don't and more bulbs in the same section burn out, you can reach a point where there's too much power for the remaining bulbs to handle, and all (or at least many) of the remaining bulbs will burn out, necessitating a replacement of the string.
Dec 15, 2011 | Christmas Lights Etc Santa's Toy Truck
It wont switch gears it stuck in 5th. what do i do?
it could be a bent shaft or a bent shifter fork
good luck.
Mar 26, 2011 | 2004 Harley Davidson XL 883 Sportster
My daughter pulled to hard on the ceiling fan pulling out the chain. i have taken it off and apart, nothing appears to be broken but im trying to figure out how to put it together so it retracks, i...
Don't even bother to repair the pull chain switch, get a new one at KMart, HomeDepot or similar store for less than $2.
Two times I've repaired one, it comes apart when I need it the most.
Good Day! Don't forget to rate this post!!
Sep 09, 2010 | Vacuums
2001 Ford Escape rear passenger window will not go up. Took inside door assembly apart and it appears the cable has come undone. We need a diagram of what it's suppose to look like, so we can fix it.
It most likely has a broken part on the cable and will need to be replaced or jump off again.
The dealer can print you a pic at the parts counter.
May 04, 2010 | 2001 Ford Escape
Primary and secondary timing chain tensioners
Need more info such as engine size.
Oct 05, 2017 | 2000 Dodge Intrepid
Tiller Blades not working
Eric,
I don't have any breakdown any more, but I believe on this tiller the chain box is bolted together with a 1,000 bolts ( well it seems like that many). remove the fender (Shield) and then you can start taking the bolts out of the cover casing of the chain cover. I have found more broke chains than broken gears..
If this helped, please rate this answer.
David
Apr 17, 2009 | Gilmour & Spray Doc& Poly Tank Sprayer...
Shocks
i would have that looked at they need to be sealed
Sep 09, 2008 | 1995 Chevrolet Blazer
Cycling Logo
43 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
