Question about Sharp MX-2300N Color Copier
Where can i purchase an exit cooling fan for my sharp mx2300n printer?
  • jheremiel Jul 03, 2011
    please advise where are you located, we can redirect you if you let s know your place
4 Suggested Answers
goodgold
  • 389 Answers
SOURCE: i have problem sharp mx2300n everytime sign replace usedcontainer
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Posted on Mar 24, 2009
  • 22 Answers
SOURCE: error code H5-01 sharp MX2300N
pascale_algu
Its a cause by continuous misfeeding. You better find the cause of that problem.
to cancel the code press program key(P), asterisks, clear key, program key . when the stand by for simulation code appears type 14 to cancel the trouble code.
Good Luck
Posted on Aug 13, 2009
hamzaskilltd
  • 316 Answers
SOURCE: where do i order a
31 Fusing FAN lock detection
Posted on Apr 13, 2011
Mx2300n sharp copier is jamming paper in between fuser unit
Restart your printer take the paper out then put it again then try to print if its still the same problem then call us on 844-499-8877 ask for sam watson
Nov 03, 2016 | Sharp Office Equipment & Supplies
Sharp mx2300n tray 3
Sounds like you need to configure your print driver with the options that your machine has on it.
Check out my instructions on how to do this!
How To Configure Sharp Print Drivers with Installed Options to print...
Apr 30, 2013 | Sharp Mx-2300n Copier Color Mx2300n...
How to check toner levels in Mx2300N copier?
Hold down the copy button and it will display the levels
Aug 20, 2012 | Sharp Mx-2300n Copier Color Mx2300n...
On the mx2300n the center tray (output tray) has a little "doohickey" that is attached, but on mine fell off---I just want to attached it in the right place.
Most likely the stack height sensor flag. Unless you're running hundreds at a time, it's not needed.
It's hard to attach in the proper position with the exit unit in the machine.
Mar 06, 2011 | Sharp MX-2300N Color Copier
Error code l4 on sharp 5316
The error means that The paper exit cooling fan is not working. Reboot machine, if the code comes back, you'll probably have to get the fan replaced. You may need a technician to this things for you, if you haven't got any idea how to service the machine.
Hope this helps.
Dec 02, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code H5-01 sharp MX2300N
pascale_algu
Good Luck
Aug 13, 2009 | Sharp MX-2300N Color Copier
I have problem sharp mx2300n everytime sign replace usedcontainer sharp mx2300n
Mar 24, 2009 | Sharp AR-C160 Color Copier
Error Code L4-31
The paper exit cooling fan is not working. Reboot machine, if the code comes back, you'll probably have to get the fan replaced. The fan is one of the two located over the right side door.
Jan 10, 2009 | Sharp MX-2300N Color Copier
Sharp MX-2300N Color Copier Logo
110 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
