Question about Craftsman Garden
I have bought a 1999 craftsman 6.5 hp, 22" weed trimmer and need a manual. Numbers on the machine are 536-7735100 and code 9105057676 and it has a Tecumseh motor. Another number is 143-996516. It has not been started in 4 years and will not start now, so I may need a new spark plug and clean fuel.
  • 376 Answers
SOURCE: Craftsman Edger 536-797520 is leaking gas from the air filter
The needle valve is sticking open. The carb needs cleaning and diaphragm replaced. Probably best taken to a shop unless you have experience with diaphragm carburetors. Dwain
Posted on May 27, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
  • 53 Answers
SOURCE: I am trying to change the string on a Craftsman Weed Trimmer
Usually you "Push in" as you turn them. Or...there is a knob with a male thread shaft screwed into place holding it all tight. Hold the spool steady as you try to turn the knob off. Or...there is simply a "nut" to take off. But for the most part the newer wacker spools usually just "push in and turn/twist" out. Simple. to reinstall it or replace it with a new one simply push and twist it the opposite removal direction. FYI most lines can be manually "rewound/refilled" by yourself and reused over and over until they really wear out. There are little tricks to doing a rewinding but it isn't anywhere near difficult to do...or learn. Usually the price of a replacement spool is 5 times the cost of rewinding them yourself. Comon its easy! If ya want I'll help ya thru it.
Posted on May 10, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My craftsman gas weed trimmer runs but lacks power...
Hi Edward,
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 25, 2010
Brand new weedwacker model#316-711370 first time started right up ran for awhile then just stopped,wont start at all now
#34 craftsman weed wacker manual
45.55.157.141/craftsman-weed-wacker-manual.html
100+ items - pdf download about #34 craftsman weed wacker manual ... Books Title
File Code
Craftsman Weedwacker Manual from Sears com
Free Craftsman Trimmer User Manuals ManualsOnline com
Aug 04, 2015 | Cars & Trucks
All I need to know is how to change the belt on a Craftsman 22 inch Weed Trimmer. #917.773710. Can't find the manual. Didn't think it would be this difficult to have such an easy question answered....
You can find a diagram for your mower here. You should be able to remove the top cover, then loosen the tensioner pulley and pull the belt right off. Put your new belt on following the original belt path. You can find a replacement belt at PartsBuggy.com here.
Aug 26, 2011 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 22" weed trimmer. is the
No, you have to manually control that yourself.
Dec 04, 2010 | Craftsman Garden
Hve a Craftsman Weed Wacker 24 cc Need to find out how to put new nilon cord in the weed wacker its been some time since i've done this.
http://www.craftsmanlawn.com/WeedWacker_Weed-Trimmer/358.795310/
Go to VIEW MANUAL. Then the process you seek is on PAGE 10.
Jul 08, 2009 | Craftsman Garden
Change cutting line
Pop of bottom cover and wrap new line by turning head or replace with different spool or blade cutter
Jul 01, 2009 | Craftsman 22" Gas Hedge Trimmer
Craftsman manual for a 4 cycle lawn trimmer
I have a craftsman incredi-pull 4 cycle, I changed 4 cycle oil, too much smoke coming from the machine, what I can do?
Nov 11, 2007 | Video Game Consoles & Games
Garden Logo
314 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
