Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My usb cable is broke how can I fix it - SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
  • Brian Sullivan
    Brian Sullivan May 20, 2011
    is it the actual cable that is broken or not just your usb connection
  • SanDisk Master
  • 27,725 Answers
Is it the actual cable that is broken or not just your usb connection
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on May 20, 2011
I need a usb port to be soldered to my motherboard, and a speaker cable from MB to connection by the DVD
Do not try the repairs, insert a USB card instead.
The advantage is that you can upgrade to USB3.
Install a new sound cable.
For the video card, Ebay.
Aug 15, 2015 | Computers & Internet
Can i fix or replace physical keyboard
You could try cutting the bad cable between the torn wires and the keyboard and then sacrificing another USB cable by cutting off the end you need along with as much wire as required, then stripping the ends of the two cables, match wire colors between the cables and soldering the connections. Wrap electrical tape around each connection and then tape all the connections together. Might work. New keyboards are usually available for less than $10 at various stores like Big Lots, K-mart, Walmart. Probably not economic to fix the thing unless it was an expensive mechanical gaming keyboard.
Aug 13, 2014 | Proscan 8" Tablet with 4GB Memory
My scanner is not connecting to my computer or is cutoff. why is this? how do I fix the problem
It might is the USB Port you are connecting it to, have you checked the other ports? Have you tried using another USB cable? If these two points aren't a possible reason, Windows might isn't updated, is infected or the scanner's USB port broke.
May 18, 2011 | Dell Computers & Internet
I broke my USB port on my Acer Aspire 4730Z. How
open the laptop, desktop pc, and remove carefully the internal usb connector, that goes to the motherboard, BEFORE ANYTHING DISCONNECT THE POWER CABLE, AND EVERY SINGLE CABLE ITS CONNECTED TO, MOUSE, KEYBOARD...ETC. then see which kind it is, and go to your local hardware store, Best Buy, Fry's, or order it online.
Reply: team.akwrite@gmail.com Irving
Mar 16, 2010 | Computers & Internet
I have a 10GB Philips 1" external hard drive. The wire that goes to the usb connector is broken, making the data inacessible. I took it to Best Buy to see if they could repair it, and they said no,...
if you can find or purchase another cable adapter just replace it. not worth fixing and might cause your external hard drive to crash if you get to fix the cable wrongly and will be spending more and losing both hard drive and cable
Jun 19, 2008 | Computers & Internet
Windows does not recognize usb device
Probably broke a solder point. Need to take in for repair, or find a friend who is an electrician.
Note: Needs to use low heat solder.
May 20, 2008 | HP PhotoSmart 7150 InkJet Printer
USB cable broke inside camera port
Buy a portable card reader. Insert in USB port. Insert your card and download. You don't need a cable then.I just bought one for $10.49 with a $6 rebate from Radio Shack.
Nov 08, 2007 | Vivitar ViviCam 5386 Digital Camera
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
53 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
