Question about Apple iPod touch
Forgot passcode on ipod touch need to unlock - Apple iPod touch
  • 731 Answers
You need to attach it to your computer and restore it through iTunes.
Be aware that all will be lost but that's the price for forgtting the code.
Posted on May 19, 2011
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
How do u unlock your touch ipod if i forgot my passcode
You will need to hook it to the computer that it was originally set up on and open itunes and restore it.
Aug 28, 2010 | Apple iPod touch
Forgot passcode and wont unlock how do I unlock it?
Try to remember your passcode because the solution that I'm going to recommend to you will wipe out all the data from your iPod touch.
If you totaly forgot, the only thing you can do is to put your iPod touch to DFU mode and then restore.
Click here for step by step instruction on how to do that.
For more iPod touch / iPhone tips, click here.
Feb 06, 2010 | Apple iPod touch
Bypass password to unlock ipod touch
No way to bypass passcode. The only option if passcode was forgotten is to connect to computer and restore with iTunes. There may be data loss depending on backup that was made and when it was last made.
Dec 22, 2009 | Apple iPod touch
Forgot ipod passcode
simply plug your ipod into itunes to unlock the code
Jul 23, 2009 | Apple iPod touch Second Gen (8 GB,...
Unlock code from ipod
It depends on the severity and the settings you have given the iPod... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
Feb 12, 2009 | Apple iPod touch
Apple iPod touch Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
