Question about Dimplex Compact Electric Flame Stove Heater
On my electralog heater, after about 5 minutes running the heat stops,fan is still running. Adjusting thermostat makes no change
    Brigadier General:
  • 4,736 Answers
From what you have described. it sound like the heating element is overheat and the automatic over heating sensor is shut it down. One of the primary reason these heaters overheat is that the become clogged with dust, lint & pet hair. Cleaning the heating element. may solve your problem. A vacuum cleaner (especially a Shop Vac) that has a hose, a brush attachment and a crevice tool, works well well in cleaning the heating element. Be sure the unit is OFF and unplugged, before attempting any cleaning.
Hope this helps you solve the problem.
Posted on May 19, 2011
DON'T BUY THIS PRODUCT MY OPINION IS THEY ARE JUNK RUNS YOUR ELECTRIC BILL SKY HIGH I'VE GONE THROUGH 2 OF THEM IN A YEAR JUNK JUNK JUNK !!!!
Posted on Apr 26, 2013
Toro porta heater only stays lit for 5 or 10 minutes then the heat goes out but the fan stays running. Re-light it and it does the same thing.
The fan will continue to run after the flame goes out to prevent the element from overheating from residual heat. It should stop after a minute or two, when the element is cooled down.
It could be a venting problem. Make sure the vents are clean. When it's not lit, air gets into it. When you light it, it slowly uses what air it has and it starves for oxygen.
It could be a misadjusted thermostat and it's turning off before you think it should. Try setting it higher and see if it runs a bit longer. My thermostat on my house furnace runs 10 degrees higher than it should, so I just keep it 10 degrees lower than it says.
Jan 24, 2015 | Heating & Cooling
Heat stops working after a few minutes
A manufacture name and what type of heater would be helpful.
Mar 30, 2014 | Electralog Home
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
I have a electralog fireplace model #cs 3311. It doesn't stay on very long. Even if i turn the thermostat up it doesn't turn on
It's probably the Temperature Cut Off Switch. It turns the heater off if it's overheating. To reset the switch turn the Main On/Off Switch to OFF . Wait 5 minutes and turn it back ON.
If you need to continuously reset the heater, unplug the unit and call Dimplex North
America Limited at 1-800-668-6663.
Hope this helped to solve your problem.
Mar 08, 2011 | Heating & Cooling
No heat we changed thermostat heater core wondering if there are fuses or relays that could be involved
Remove rad cap start vehicle be sure engine antifreeze is full.After running for 5-10 minutes you should see air bubbles rising nonce they stop close cap you should have heat.If you do not perhaps you might consider removing the thermostat to make sure the spring side of thermostat is facing the engine and not the thermostat housing.
Dec 15, 2010 | 2000 Ford Expedition
I have a cs1205 electralog heater. after 5 minutes we hear a pop and the heater stops working. we shut it off and will hear a pop then turn it back on. it will work again for about 5 minutes. what is wrong...
I have an electralog cs1205, when i turn it on, although it works , after about 10 seconds it makes a strange noise. It never did this before. Any ideas on whats wrong?
Nov 27, 2010 | Dimplex Compact Electric Flame Stove...
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Nov 07, 2008 | Honeywell Focus 6300B 5-2 Days...
Dimplex Compact Electric Flame Stove Heater Logo
1,287 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
ashburton
Kory Ronning
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
