Question about Delta Faucet Company RP26755 Sleeve Assembly for Delta 2300 Series Faucets
We have the delta 2300 series shower dual controls my husband took off the control for the flow nothing blocking He went to take off the control for the hot & cold flow. do you have any manuals for it.
  • 731 Answers
A picture is worth a thousand words"
Posted on May 19, 2011
Flow rate on delta thermostatic valve
the two screws are service stops open them all the way
Jun 09, 2012 | Delta & Single Handle Shower Faucet
We purchased a home built in 2001 that has the dual handle Delta Monitor 2300 series. Though this particular model, I believe, is designed to prevent this problem, my daughters are practically scalded...
There is probably mineral or rust deposits in the cartridge. Shut the water off and remove the handle and then the faceplate and remove the cartridges. Tap the cartridges and see if any debris comes out. You can try cleaning it out buy soaking it in a bowl of warm white vinegar. Keep moving it around and keep flushing the inside of the cartridge out and tapping it. There is usually a small check valve in the cartridge and you should here it rattle. With the cartridges out turn on the water supply for a few seconds to flush out the pipes. Then try reinstalling them or while they are out; go to your local plumbing supply or Home Depot or similar and purchase some replacement cartridges.
Thanks for using FixYa
Jun 20, 2011 | Delta Faucet Company RP26755 Sleeve...
Water comes out both spout and showe head when temperqture control is adjusted
Something is blocking the flow thru the tub spout. Make sure the dirverter moves properly. It mat be stuck partialy closed.
If that does not work take the tub spout off and see if you still have the problem. If that fixes it get a new tub spout.
Mar 31, 2011 | Delta & Lockwood& Tub & Shower Faucet
We have two showers with Delta single lever faucets. Both have given us problems. Both allow little or NO hot water through the shower head. What can we do?
It sounds like there's a blockage in the valve. It needs to be removed to see if water is blocked and confirm you have hot flowing freely.
Nov 23, 2010 | Delta & Single Handle Shower Faucet
How to fix a dripping Delta Monitor shower controls?
Turn off the water, disassemble the control and replace all rubber pieces and damaged plactic, if any.
Sep 21, 2010 | Delta Monitor 13 Series Chrome Trim...
Low shower head flow from Delta R1824 shower
Try exchanging the Delta head with one of the other shower heads you are happy with if you haven't already done so. No change in the flow means it's not in the head, and change means it is.
If it is in the head, since you are on a well and not a municiple water supply, you might consider removing the factory install flow controll device located just below the threaded area that mounts to the shower arm. These inserts can be a real bugger on some heads and each one is a little different than the last. The trusty nail often works well.
Your body sprays, I believe, are factory fixed at something like 2.2 gpm and non adjustable.
Also consider for a moment a garden hose with trigger spray head on it. When you squeeze the trigger the water will shoot out a certain maximum distance. If you were to take an ice pick and poke a hole in the hose, that maximum distance will be slightly reduced. The more holes in the hose the less the maximim distance. Correspondingly, the more holes you poke the less distance each hole will squirt because you have the same pressure and volume of water but more exit points.
A monitor has a flow rate of about 6 gpm at 85 psi which is pretty average for shower valves. If your other showers have only one exit point(i.e. one head) and the R1824 has 3 with the same pressure and volume, the garden hose illustration can also explain the volume change as well.
May 30, 2010 | Delta Home
We have a newly installed Delta single-handle shower faucet and cannot figure out HOW to get a warm water mix. No matter where we turn the handle, we get different temperatures of "cold."
That is a graduated water mixer valve, and it sometimes has a little white water restrictor blocking flow from your hot water port. See if that was left in by removing the handle with all water shut off to the valve and reattach then try again. This can also happen if you have a tankless water heater because pressure controls heat. Typically a Tankless water heater system will require little, to no cold water to your bathtub valve because of the heavy water flow at the tap. Remember, flow equals temperature. Less flow = more heat, more flow = less heat.
Mar 09, 2010 | Delta & Single Handle Shower Faucet
Low pressure on Delta 1400 series shower head
The Shower Valve is regulated to give only 2.2 gallons a minute. If you have the shower head off test how many seconds to get an approximiate gallon running in the middle hot/cold position. If longer than 30 seconds either the stem in the valve is clogged or the water lines to the valve are too small or kinked.
Phil
Dec 05, 2008 | Delta Faucet Company RP26755 Sleeve...
Delta Faucet Company RP26755 Sleeve Assembly for Delta 2300 Series Faucets Logo
859 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
