Question about Hitachi Televison & Video
I have a hitachi50v500a no sound or pic all light's on front come on but the lamp light stays on is this mean i need a new lamp blub
  • 373 Answers
Yes, It is likely to need a lamp go to pureglare.com First take the lamp out (access probably at the front of the set behind the removable grill panel and then remove a square door with screwdriver) and inspect it to see if the glass is broken inside the bulb or if there are any glass particles inside the bulb.
Posted on May 20, 2011
I am looking for the parking lite fuse on 1992 geo metro conv
that means there is short in the park lamp feed.
its the largest feed on all cars, and very hard to find, if visuals of harness show no damage, and you remove all 4 tail and front light bulbs. the light blubs with brass (yellow) metal bases, LOVE to short.
remove all 4 and try new fuse.
http://www.fixkick.com/power-elect/blows-fuse.html
all ways to find a short are there ,even Duanes video.
Jul 08, 2014 | 1992 Geo Metro
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
TV has good picture sound and picture keep going off up to 2 minutes then returns. Its a sony LCD projection TV 65"
The tv "LAMP" LED light indication staying on or blinking on the front tv bazel frame?The tv projection lamp been inside this tv like 1 1/2 or 2 years?Tv been on and watches like 4 or 5 hours daily?Yes to all of these,mean the tv projection lamp life are ending.Require a new projection lamp for the tv.
Jan 14, 2011 | Sony Televison & Video
The lamp light on the front of the tv is flashing and it sounds like a burnt out light bulb when you turn it on. is there a reset button on the tv
TV "LAMP" LED light indication flashing or staying on front of the bazel frame.Mean this tv have a dead projection lamp.The tv must have it tv projection lamp replacement.To make the tv to work again.
Jan 05, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
We have a shaky pic, we have sound and everything else... we opened it up and the LAMP we were told was that problem doesn't exist??? The color lamps are all working and HUH???
Only DLPs have Lamps,LCDs have Blub, Projections have 3 Tubes RED_GREEN_BLUE Look for Bad Capacitors they are sometimes swollen,vented or Puffed up on Top.
Jun 26, 2010 | Toshiba 50HX70 50" Rear Projection...
When i turn the tv on the screen stays black and the light on the front lights up red on the Lamp button?
Lamp light lit, that means TV needs new lamp.
Replace lamp in TV as existing lamp is dead/ broken.
Thanks.
Dec 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Red lamp light stays on. No pic or sound. Can I get a new lamp and change it myself?
No. This model does not use a lamp. Could be a hundred different things cause this symptom.
Mar 30, 2009 | Hitachi 51F59 51" HDTV Projection...
Infocus IN24 lamp not lighting up
MAKE SURE BLUB WIRING IS THE SAME AS OLD BLUB, IN24 AND IN24+ WIRING IS DIFFERENT IN CONNECTOR.
Mar 20, 2009 | InFocus Projector Lamp for IN24+, IN26+
Televison & Video Logo
18 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
