I have set a program on my honeywell rth2310 tstat and was wondering if i can lock it out so no one can override the settings
    Guru:
  • 683 Answers
Http://customer.honeywell.com/techlit/pdf/PackedLit/69-2214EF.pdf
go to this web site this is the manual for your stat and it will tell you everything. Thanks and have a nice day.
Posted on May 19, 2011
I don't remember the security code to change the settings.
Depends on what t-stat you have. Need a make of tstat and model # or style.
May 25, 2015 | Honeywell THX9421R5005 Prestige IAQ...
How do I set the temporary or permanent override feature on the Honeywell RTH2310B model thermostat?
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Jan 25, 2011 | Honeywell Programmable Thermostat Heater
The filter needs to be replaced on my RTH2310. Where is this filter and how do I replace it? Libby
No the tstat just has a reminder to replace you system stat. There should be a rest for it. And the filter should be in the air handler/Furnace
Aug 28, 2010 | Honeywell Electronic Programmable...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Message: "in recovery"
the "in recovery mode" is refering to a thing called energy recovery management its one of the features on your tstat what it does- when you are using the program on your tstat the "in recovery" starts your unit early so if the tstat is set to be 70 degrees at 8 in the morning when 8 o clock hits it will already be 70 degrees in your house you can turn this feature off if you want in the installation setup codes
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Programmable thermostat intermittent problems...
Some tstats control humidity as well. Temp will over shoot set point in order to reach humidity s
Jun 24, 2017 | Honeywell Programmable Thermostat Heater
New rth2310 themostat does not blow cool air
I don't believe you're going to get the new one to work -- sounds like it doesn't have enough control wires to operate your HVAC system. If it is designed to operate a 7-wire system, the documentation should show how to hook the 4-wire tstat so it will work.
Apr 21, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
