Question about Ingersoll Rand Air Tools & Compressors
I am trying to put a tune up kit in but cannot get the inside out to get to the rear rotor bearing and rear end plate gasket that I want to replace.Is there a tip or trick to finish getting it apart?
    Habit-Forming:
  • 102 Answers
After removing the hammer case and hammer assembly, thread the screws on to the housing, tighten down the screws, next spray some penetrating lube in to the motor, make sure that the cylinder is pushing against the rear endplate, grasp the end of the rotor you can use a locking plier or a vise, MAKE SURE TO TAP ON THE SCREWS AND NOT THE HOUSING, as the motor slides out make sure that the cylinder is pushing against the rear endplate until the motor is completely out, in an extreme case it may be necessary to heat the motor housing.
Follow this link to find the parts list for your model:
Ingersoll Rand Industrial Technologies On line Publications
Posted on Oct 13, 2014
Ir231 has very low power output-what can be wrong-took apart -can't see anything wrong
Might be a little late but did you make sure your reversal vale is set to #5 on each side when you switch it from forward to reverse? There is a little ball and spring that gets weak and the vibration will allow it to move out of position causing your tool to become weak. If everything looks good get a 231tk3 kit and put it in the tool. There is a rear gasket behind the rear plate inside the tool that could be blown. When pulling the rotor and rear plate assembly you might need to apply some heat to the aluminium housing when you remove and install it if the housing is tight.
May 08, 2015 | Ingersoll Rand 231C Air Impact Wrench
Runs untill you try to remove a bolt
I would check my reversal valve and make sure the knob is on the number 5 on both sides first and check my air inlet for trash. Other then that I would tear it down and inspect the tool for any broken parts or grooved front and rear plates in the air motor. If it all looks good I would order a tune up kit with bearings and replace everything that they give you in the kit.
IR 231-TK3
Oct 29, 2012 | Ingersoll Rand 1/2" Super Duty Air Impact...
I have 2001 mercury marquis Lf rear parking brake popped how do I remove the rotor
Cable and linkages are likely seizedwith rust and/or ice. Remove bottom caliper bolt to remove caliper up and off rotor.Un-bolt caliper support to allow removal of rotor. Make sure parking brake eyelet protruding throuth backing plate isin the off position that is pointing to rear ofcar; secure with vice grips if necessary.Now proceed to tap rear face of rotor all arround on inside to remove Depending how badly it is corroded and internally seized,(also worn groove) ,rotor and internalparking brake shoes will have to be sacrifiiced and replaced. Purchase new hold - kit emergency brake shoes and rotors for both rear wheels
Feb 02, 2011 | 2001 Mercury Grand Marquis
Swap 84 chev. van rear end instructions
FIRST THING IS GET IT UP AND TAKE THE COVER OFF THE REAR END PULL TIRE AND BRAKE DRUMS NOW TAKE THE SMALL BOLT OUT OF THE CARRIER AND REMOVE THE LARGE PIN NOW PUSH THE AXLE IN AND THE C CLIP WILL COME OFF PULL THE AXLES OUT AND UNBOLT THE BACKING PLATES AND TIE THEM UP DO NOT TAKE OFF THE BRAKE LINES THIS WAY YOU DONT HAVE TO BLEED BRAKES OR CHANGE ANYTHING OVER TO THE NEW DIFFERENTAL TAKE THE BRAKE LINES OFF THE CLIPS THEY JUST BEND OVER AND OULL DRIVESHAFT AND U BOLT AND LOWER IT OUT TAKE YOUR NEW DIFFERENTAL AND PULL THE COVER AND REMOVE THE AXLES BEST TO INSTALL NEW SEAL AT THIS TIME CHECK AXLES FOR ANT PITTING WERE THE BEARING RIDES IF YOU SEE ANY REPLACE AXLE AND BEARING ( THE AXLE IS THE RACE OF THE BEARING) PUT IT UP BOLT IT DOWN INSTALL BACKING PLATE AND AXLES NEW COVER GASKET OR SEALER MAKE SUR ITS CLEAN AND DRY WITH SEALER AND FILL IT UP WITH GEAR LUBE YOUR DONE
Oct 15, 2010 | Chevrolet G20 Cars & Trucks
Leaking fluid from the rear area of 99-venture
Your rear end is most likely cause of this. There is a plate gasket on the back, and 3 rubber gaskets that go on either axle and the drive shaft that would be leaking. I would do a closer inspection to see which one is leaking and replace it as soon as possible because depending on how fast the leak is if the rear end runs out of fluid the bearings could burn up and it isnt cheap to fix that. Hope that helps!
Jul 30, 2010 | 2004 Chevrolet Venture Passanger
My 2002 chevrolet 4wheel drive makes a noise alot like that of a break rubbing.It stops as the speed increases, I changed all four brakes and rotors and also changed the universal at the rear end. what...
Make sure backing plates behind front & rear rotors aren't rubbing on rotors. Jack up each wheel individualy & spin. May also be emergency brake shoes rubbing inside drum inside rear rotors.
Jun 24, 2010 | 2002 Chevrolet Silverado
Grinding noise on drivers side rear axle bearing
Remove the wheel and check the brake shoes/pads and the drum/rotor. If they are both fine, then you'll have to remove the axle and check the bearing. To do this, remove the retaining bolts on the plate just underneath the end of the axle where the tires mounts. You may need a slide hammer or axle puller to get the axle out, especially if the bearing has deteriated substantially. Once you get the axle out you'll have to take it to a parts store or machine shop and have the old one pressed off and the new one pressed on.Driving them off or on with a hammer can damage the axle where the bearing seats or the new bearing. If the bearing has seized, check to make sure it hasn't damaged or scored the bearing seat inside the rear end housing.
May 25, 2010 | 1999 Ford Expedition
Need to remove and replace rear rotor
You have to remove the axle shafts first as it has a full-floating axle, then pull rotor and hub off the axle housing. Unbolt rotors from hub. Check bearings and seals in hubs and the axle snouts where the bearings run before installing. Put new flange gaskets on axle and torque flange bolts to 95 ft-lbs.
Apr 11, 2009 | 2004 Dodge Ram 3500 Truck
Air Tools & Compressors Logo
214 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
