Question about Samsung SyncMaster P2450H 24" Wide TFT Screen LCD Monitor
I have a samsung moniter itts about 2 years old lately the picture keeps going grey like a lack of contrast,I have checked monitor leads i dont lose picture. I am a novice coulde it be my pcs graphics card ?.How can i test my monitor ?
  • 917 Answers
If you mean by lack of contrast, that the screen illumination is low, then you probably have a faulty backlight, i.e. one or more of the cold cathode flourescent tubes is not working. Although this may be repairable, it may be more economical to buy a new monitor. Get a quote from a TV repair shop.
Posted on May 19, 2011
Monitor colors lack contrast
Try using a preset picture setting & then compare that to your manual setting seems like you have gone out of sync.
May 09, 2015 | Acer AL1917W LCD Monitor
Contrast menu keeps popping up in my moniter,it is a hcl moniter,the menu is not the normal adjustment menu that appears in the moniter which has all options like colour,brighteness etc.its just like a...
mmm look you have a setting problem reset the screen to it's defulat if it didn't solve the problem you will have to change the press bottoms and you will need some who know electronics to help you with the board but first try to rest it to the defulat settings
Nov 15, 2009 | ViewSonic VA721 17" LCD Monitor
Moniter doesn't stay on
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you have additional questions just email me. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 10, 2009 | Samsung SyncMaster 225UW 22 inch LCD...
Moniter Display Problem.
Either cable contacts inside your monitor is not proper or the data cable is faulty. Monitor repair is required.
Dec 13, 2008 | LG Studioworks 563N 15" CRT Monitor
LG FLATRON 915FT plus monitor OSD setting
1. clean the G4 wire.
2. change the neck base.
3. adjust the focus preset in LOT .
Oct 16, 2008 | LG Computers & Internet
LG 700E MONITER britghtness and flicker
trace abl from fbt to video preamp ic.
replace ic if nothing found bad.
Sep 23, 2008 | LG Studioworks 700S 17" CRT Monitor
Monitor not powring on
How to unlock Samsung SyncMaster 753S (Ivory) 17" CRT Moniter
Mar 31, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Screen goes black with bright white horizontal line
This problem of loss of vertical deflection with the line offset from center suggests a cold solder connection in the vertical sweep circuit or in the power supply to the vertical sweep circuit. Most service shops should be able to fix.
Jun 30, 2006 | LaCie Electron 19" CRT Monitor
Samsung SyncMaster P2450H 24" Wide TFT Screen LCD Monitor Logo
142 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
