Question about HP Pavilion dv6000z Notebook
How to replace the internal secundairy battery
  • cullendwyer
    cullendwyer May 19, 2011
    What internal secondary battery? Never heard of one. There is one battery pack and AC supplied from an outlet. Are you talking about the battery itself?
    Sergeant:
  • 281 Answers
Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck. Easy solution but sometimes hard to do because of close quarters.What you need to do is locate the watch battery inside of the lap top.It may be under one of the back panels but not all ways.If you have to open the case it is super easy to break something and some will only open an inch because of a small electric ribbon hooked to the top board.What you do is remove the watch battery for ten minutes and then put it back in.Be sure and ground your self by touching the metal frame because if you have any static electricity and it jumps to the mother board it will fry the motherboard.If your not handy with delicate work I would take it to a technician. Good Luck.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 20, 2011
Won't turn on, left unplugged for months and then it worked for a couple of months and now won't turn on
Most times caused capacitor problems of well deformed capacitors with to tigh voltage tolerance replace if find bulged or leaking ones with 10 volt higher models the protection mode should after start being activated because of secundairy power supply voltages are no longer smooth flattened and become too high, A heartfelt tip for research , do not use a variac to circumvent the protection power supply voltage without the use of a 200 w lamp in the serial ac line of the primary circuit when troubleshooting , or it will fire -out otherwise undetected a few piece of sometimes hard to get expensive active components.
good luck
Nov 01, 2015 | Philips 52PFL5704D 52 in. HDTV
Time setting on camera is lost every time i turn off ,changed battery, with correct one
The internal battery is depleted. In some cameras it will charge off of the removable battery after several hours, if the internal battery is still good. Otherwise you must replace the internal battery which is a watch type battery.
Mar 09, 2015 | Cameras
Apc smart ups rt 10000 internal fault, what to look for?
you should check the inverter and the charger boards as well.
Mainly IGBTs and drivers (IGBT drivers).
better locate the fault and replace the defective board
Aug 21, 2014 | APC Smart-UPS RT 10000VA - UPS ( external...
My computer had a message that the internal battery was low and to replace. The computer now will not turn on. Where can I get an internal battery and can I replace it on my own. I own an HP G60-235DX.
that internal battery is the cmos battery, its the one that looks like the watch battery.
steps to change it :
http://www.ehow.com/how_6914231_change-cmos-battery-hp-laptops.html
Mar 01, 2011 | HP G60-235DX Notebook
Funny noise when plug in to the PC internal battery not charging
Its possible that the internal battery has gone bad and is shorting out when you plug it into the PC.. I would recommend not pluggging it in to anything until you can get the internal battery replaced as it may damage the PC/other device too.
Flip camcorders are very popular so finding a replacement battery should not be hard.
Sep 01, 2010 | Pure Digital Flip Video Ultra Camcorder
My internal battery is depleted. how do i change
Do you meant Korg M1 ?
How to replace Korg M1 internal battery, read HERE
FixYa can only give you the guide requested but for DIY, you are responsible for your own repairs.
Jul 24, 2010 | Korg TR76 76 Key Synthesizer Workstation
TV was struck by lighting. Would like to try to repair if possible and not too expensive
Check for damage on the secundairy ground near optocoupler ,if so then don't even try.
Jul 31, 2009 | Sanyo DP26648 LCD TV
Canon sd750 does not hold date/time setting
yes there is a internal battery the camera has to be opened up to replace it. we replace the battery on this model for 45.00
Jan 26, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Date/Time problem
Hi all, same problem happened also with my S304. I' ve deassembled it and there IS an internal battery on one of the pcb's inside. So, i'm sure that if this is replaced by a new one, this problem should be fixed. Replacement will be a little bit tricky as the battery is soldered internally. If i have found the right type of battery, i'll post it, but this can take a little time ;-) F
Apr 23, 2007 | Fuji FinePix S304 Digital Camera
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
