Question about Whirlpool Ovens
My oven, a SF375PEE, does not work; surface burners and broiler are OK, just the Bake function doesn't work.
  • 42 Answers
SOURCE: Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Posted on Jan 26, 2009
  • 22 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
heatman101
  • 43501 Answers
SOURCE: ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Mar 30, 2010
  • 1891 Answers
SOURCE: gas in oven wont come on,burners and broiler ok,
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Posted on Jul 16, 2010
SOURCE: Oven Stopped Working..
It sounds like the igniter. The oven is not getting a spark to turn on, and heat up. We had the same problem, but changed the igniter, and it works fine. Good luck!
Posted on Feb 13, 2011
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
I have a whirlpool gas oven model # SF367LEKB and the oven will not ignite. You can hear the ignitor clicking but it will not light. The broiler and four burners work fine. This happened several months...
What you need to check is if the spark is strong at the bake burner.To do that remove the oven floor and the flame spreader under the oven floor, set the oven to bake and look for a good bright spark. If the spark is good the bake burner needs to be replaced,if it's a weak spark the electrode(spark Plug) will be needed.
The part numbers are
Bake burner 8054077
Electrode 8054129
They could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
assuredparts.com
applianceparspros.com
I hope this will help youto beable to repair your oven,
Gene
Aug 06, 2011 | Whirlpool Ovens
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
Jul 13, 2010 | GE JGRP17 Gas Single Oven
Kenmore gas oven model 91136519 from 1992 . The stove top burner work as well as the oven broiler. But the bake mode of the oven will not come on. What could be the problem?
Faulty temp. control...The variable temperature portion is faulty, but broiler function FULL ON GAS is ok...Replace the Temp control assembly.
Jul 01, 2010 | Ovens
Ge profile gas oven broiler works but bake wont light
heatman101
Mar 30, 2010 | Ovens
Gas oven does not light
I called the service where the item was purchased.
You were no help at all
Dec 03, 2009 | KitchenAid Ovens
Broiler on top works but oven wont ignite
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
It might be possible that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
If you want to see a line drawing and a parts list showing the ignitor(s), go to searspartsdirect.com and enter in the model number of your oven and click on the links shown.
Hope this helps and best regards!
Jul 31, 2009 | Ovens
Apr 25, 2009 | Ovens
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
56 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
