Printing job stopped, service error 49.2F90 appeared
  • 1,915 Answers
This is likley caused by an older version of the firmware begin used with a newer printer. Go to HP.com and on the top right of the page you will see software/downloads. Enter your model number and you will have the option to download drivers and other software. You want to find the firmware update and then download it. There are instructions in that file on how to install. As you do not state the model of printer I cannot really be that specific.
Posted on May 20, 2011
Document will not print; status reads deleating-printing; printer appears to be frozen; does not print any other items...
Kill the job on computer that sent the print job. If the job fails to clear you can stop and start the print spooler
Right click My Computer > Manage > Services.
Right click Print Spooler > Stop then Start. That should clear the job.
Same principle pertains to a network printer, but needs to be done print server.
Sep 24, 2012 | Lexmark International Lexmark 8300 Series
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
My hp deskjet 5550 will not stop printing the last print job.
HI there,
Please reset the print spooler. Go to Start then click Run (or window key + R) and this should open a run window. type services.msc and click on OK. Services window should appear. Look for Print Spooler service and stop and restart the service. This should clear the pending jobs queue for your printer.
Hope this helps.
Sep 12, 2011 | Computers & Internet
49 ff95 service error for hp 5200n LJ
A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other
causes include poor-quality parallel cable, poor connections, or home-grown programs.
1. Turn the printer off and then on.
2. Press Stop to clear all print jobs from the printer memory.
3. Turn the printer off and then on.
4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message only appears when using certain software programs, contact the software program vendor for assistance.
5. If the message persists with different
software programs and print jobs, disconnect all of the cables and turn the printer off.
6. If the error persists, perform a firmware upgrade.
7. Remove all DIMMs, EIO devices, and CompactFlash solutions.
8. Remove all EIO devices.
9. Turn the printer on.
10. If the error does not persist, reinstall the DIMMs, EIO devices, and CompactFlash one at a time.
NOTE You must turn the printer off and then on when reinstalling each component.
11. Replace the DIMM, EIO device, or CompactFlash if necessary.
12. Reconnect all of the cables.
Jul 16, 2011 | HP LaserJet 2420dn Printer
HP L7780 error on printing.
Uninstall completely all of the software that came with unit and then reinstall it.
And HP customer service sucks - they will only help you out during the warranty period of their product.
Mar 22, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
Problem with our printer 5200tn ...error 49 4c02
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
On rare occasions, the formatter is at fault
which typically appears as a 79 Service Error.
Dec 18, 2008 | HP LaserJet 5200tn Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Cannot delete print job
click settings-control panel-administrative tools-services-select 'print spool' from the list-in dialog box click stop-and again click on start. Hope this solves your problem.
Jan 17, 2007 | HP PSC 1315 All-In-One InkJet Printer
148 people viewed this question
jasbo
jasbo
