Question about Zanussi Washing Machines
Hi, I have a problem with a Zanussi JetSystem FJS 1225W. It is not completing it's cycle and flashing error E90 which isn't listed in the error numbers?
  • stu2163 May 19, 2011
    Thanks very much Rick. I won't have time to do this until the weekend because it's now 23.43 in the uk and I need to get to sleep but I will have a go and get back to you soon. All the best, Stuart
  • stu2163 May 22, 2011
    Thanks very much Rick. I have done what you said and it seems to be working fine now. 5* service. Best wishes, Stuart
  • 1,998 Answers
Heres how to fix the error code 90 use a hair dryer on the circuit board while while moving the 5 blue wire connector this seems to be the common cure to the situation on the error code 90 and this mainly happens due to condensation or moisture on the control itself E90 appears to be caused by faulty connectors to the main circuit board which appears in the bottom right corner, if you're looking at the washer from the front with the lid off (looking down into washer). This is fixed by reseating, cleaning the connectors. You have to remove the lid by unscrewing the two screws on the rear of the machine and sliding the rear panel towards the rear of the machine which will give you access to the control if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks Rick
Posted on May 19, 2011
  • Rick Ead
    Rick Ead May 19, 2011
    your welcome stuart just message me back when you have completed your repair go get some rest thanks again Rick
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    Tumble dryer displaying E90 error
    do you have the machine's manual ? if you do try and find out what the message mean
    Mar 23, 2012 | Zanussi ZDC5350W Electric Dryer
    My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
    Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
    Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
    Zanussi jetsystem 1400- error e90
    e90 is configuation problem reinstating configuration code may fix this(not easy to do) or electronic has lossed communication with display board. can be a bad connection between electronic and front display board. faulty electronic board the most likely.
    Jul 23, 2010 | Zanussi FJS1225W Front Load Washer
    I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
    Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
    Hope this helps.
    May 19, 2010 | Zanussi FJS1225W Front Load Washer
    Hi, ive got a zanussi jetsystem excel 1250 FJS-1397W model washing machine. it wont empty the water after a wash. could you tell me what to try or whats wrong? thank you, fiona
    Locate and clean filter, which should be at bottom front right of washer, behind drop down or push down flap.
    Unscrew anti-clockwise to remove and clean.
    Jan 31, 2010 | Washing Machines
    All lights flash and error E90 shows on my Zanussi ZWF1631 washer
    e90 is a cable problem linking main board to user board on the front
    Jan 12, 2010 | Washing Machines
    E90 fault
    Blue wiring loom that goes to the front control board from the maim control PCB has bad connection on the user interface.Clean PCB terminals and crimp connector to make connections tighter.if this doesn't work could be user interface fault or main PCB fault.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    Sep 02, 2009 | Washing Machines
    Zanussi Turbodry jetsystem 1200
    hiya
    e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
    hope this helps
    please dont forget to rate the helpfulness of this reply, thanks kj
    Jul 08, 2008 | Zanussi FJS1225W Front Load Washer
    Washing Machines Logo
    219 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
