Question about Actiontec (GT704WG) Router
I'm trying to turn on DCHP on router to establish network connection for Xbox Live
    Problem Solver:
  • 18 Answers
According to the generic version of the manual for your router (Because you did not say which broadband ISP you were using) the DHCP server is on by default in the router, so unless you turned it off it should be on and trying ti pass out IP addresses
My Xbox360 sometimes has problems dropping its connection because I use Wi-Fi. If you can use a wired connection that would be much better.
If you did change the DHCP server settings and turned it off, you will have to setup the Xbox by manually assigning an IP address, Subnet mask (usually 255.255.255.0) and the default gateway (Also displayed as GW).
The only other setting you would need to add to the Xbox360 is the DNS server but you should set that to the same IP address you used for the default gateway.
Hope that helps.
Posted on May 20, 2011
Netgear RP114 Stopped connection with Xbox Live.
You say "it does connect to other computers on my network (Media Streaming) through the router" but it's not connecting to "Xbox Live"? If so, it sounds like a problem with your Xbox Live subscription.
Jun 08, 2017 | NetGear RP114 (RP114CN) Router
I have a D-Link Router, with an antenna that screws off, and now won't tighten. The entire copper piece outsde the router comes out. One month ago I was able to connect to XBOX LIVE, but now It wo
yes it can be, one antenna receives(Rx) and the other transmits(Tx)
other reasons are
1.) encryption of the router is set wrong
2.) router firewall maybe blocking (put Xbox into the DMZ)
3.) router was hacked and you no longer have control of it.
4.) you have been ban by Xbox live (check your email)
5.) Xbox wifi may be damaged or off.
theres more but start with the easy ones first.
Jul 08, 2012 | Computers & Internet
I got a Motorola wired modem and it dosn't let me play xbox live why?
you may have to open a port that you xbox can use to connect to xbox live
    • 1 Connect only your Xbox and computer to the Internet. Disconnect all other devices. This is done to easily determine the Xbox's IP address, which is used in the Port Forwarding process.
    • 2 Open the Windows Command Prompt from the Start Menu. Click "Start > Run...," then type in "cmd" and hit "OK."
    • 3 Enter "ipconfig" n the command prompt. A list of IP addresses pop ups. Write down the IP address of your computer.
    • 4 Open your router setup utility through a web browser. Use the given directions from your router manufacturer to do so. Generally, the configuration page is opened by inputting the router IP address into the URL in the following format: http://123.456.7.8/ (where the IP Address number is unique to the router manufacturer).
    • 5 Open the "DCHP Client List" section of the router setup utility. This lists the devices currently connected to the Internet through the router, which is your computer and Xbox. Write down your Xbox's IP address (in this case, the one that is not your computer's IP address).
    • 6 Navigate to the "Virtual Servers" or "Port Forwarding" menu in your router setup utility. Most manufacturers have a side menu on their router setup utility, which is generally a section under your "Firewall" settings.
    • 7 Input the following port numbers and your Xbox's IP address into your router's port forwarding configuration:
      TCP 80
      UDP 88
      UDP 3074
      TCP 3074
      UDP 53
      TCP 53
      Placing these numbers in the port forwarding menu opens up the required ports that your Xbox needs to connect to the Xbox LIVE network. Save this configuration.
    • 8 Start up Xbox LIVE to check your connection. If you have no problem connecting, then you have successfully forwarded the required ports.
Jun 04, 2011 | Video Game Consoles & Games
My xbox is connected through my pc, to the internet via ethernet cable. My pc is on a wireless network, which uses a BT-homehub. Now my internet on my pc is working perfectly fine, but my xbox is says it...
make sure that the under your Local Area Connection properties, under Sharing Tab that the ICS is checked. this should solve your problem...enabling this makes your computer a DCHP capable server...
Hope it helps!
Feb 17, 2010 | Computers & Internet
Networking problems
Ok you need to set DHCP OFF, go to Start>>RUN>>services.msc then scroll down until you find DHCP Client,. set to OFF & disable it. Reboot. Now login to router and ensure DHCP is ON. That is that problem sorted. So try that.
ADSL Zoom x6 5590 DNS 360 Problem
Yes the router assigns an internal IP address. connect it up then using your PC go into the configuration of your router (http://10.0.0.2) and look under system status, scroll to the bottom and under DCHP status you will see a list of all clients connected. Your Xbox will be listed along with its internal IP address.
Jan 04, 2009 | Zoom X6 (5590) DSL Modem (55900003)
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
    On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.
    On the Xbox 360, use the "Test Xbox Live Connection" option instead.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
The microsoft wireless adapter on my Xbox360 does not connect to my wireless network
How Can I connect a network adapter from my room to downstairs about 20 yards away?
I need XBOX LIVE badly, everyone has it cmon FIXYA help me out on this.
The router downstairs is a TalkTalk modem help me!
Jun 28, 2008 | Computers & Internet
Actiontec (GT704WG) Router Logo
49 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
