Question about Camping, Backpacking & Hiking
I have a 1994 Coleman Sequoia Popup camper with a lift system. I don't have the manual. I think it needs some hydrolic fluid but I can't find where the fluid goes in it. Can you help please?
  • 36 Answers
SOURCE: I was giving a 87
I hope this help's you:
Website: www.popupportal.com
Top of the screen : Owner's Manuals, click on it and scroll down to Coleman, click on and download your file.
Have a nice "Summer"
Posted on Apr 28, 2008
shannongreer
  • 75 Answers
SOURCE: I need a owners manual for 1994 coleman pioneer cheepasake popup
http://www.colemantrailers.com/download-owners-manuals
Posted on May 12, 2009
  • 127 Answers
SOURCE: COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Posted on Jul 02, 2009
savindude
  • 175 Answers
SOURCE: I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
RonPark
  • 855 Answers
SOURCE: Trying to locate a manual for a 1985 Coleman
Have you tried e-bay or craigs list? Also try googling it, or look under camper manuels. It may take a little research but something should be out there.
Posted on Aug 31, 2009
How can I get a 2000 coleman sun valley pop up camper owners manual
Unsure if this is the same model: free manual online
https://cdn.shopify.com/s/files/1/0273/4347/files/2000_owners_manual.pdf?13230720448029520186
Parts manuals - possibly different model:
http://www.campersolutions.com/home/coleman-parts-manuals/2000-coleman-popup-camper-repair-parts-manuals
Apr 22, 2018 | Coleman Sport & Outdoor - Others
I need owners manual for 1995 coleman popup camper.I is a colman seneca.I bought it used and there was no manual with it.
If your looking for Coleman owner manuals or brochures call Beckley's! We have the last copies of these brochures straight from the factory. Limited quantities available so call 800-598-4048!
Pop Up Owners Manuals
  1. 1974 - 2011 Coleman Folding Trailer Owners Manual
Nov 01, 2014 | Sport & Outdoor - Others
Where do you put hydrolic fluid on a fifty's fordson dexta tractor
what hydraulic fluid are you trying to add gearbox of the lifting gear ?? if the lifting gear i think its under the engine cover but its been 40 yrs since i done one
Nov 23, 2011 | Cars & Trucks
I need the threded rod assembly that cranks up the hard top on my coleman popup camper 1994 i think
IF YOU HAV THE OLD 1 . CHECK AROUND TO YOUR LOCAL CAMPER , OR MACHINE SHOP OR WELDING SHOP, IT MIGHT BE REPAIRABLE.. IF NOT CHECK THE WEB FOR CAMPER CLUBS OR FORUMS .. JAY
Jul 23, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Trying to locate a manual for a 1985 Coleman Sequoia Pop Up Camper
Aug 31, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
I was giving a 87 Coleman popup camper...but needs a little care and parts along with manual...do you know where I can get this information...
Apr 27, 2008 | Coleman Campfire Grill
Camping, Backpacking & Hiking Logo
127 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
