No sound headphone microphone - Computers & Internet
    Problem Solver:
  • 5 Answers
What brand is the computer but is probably a driver not being installed
Posted on May 19, 2011
Pc headphone volume driver
3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
Click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or you might have to depending on your operating system
Click start Control Pannel
Click on Hardware and Sound
Click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Feb 18, 2013 | HP/Compaq P4 System - WinXP Pro/Office...
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
click on Hardware and Sound
click on Sound
select that!!
Hope this helps.
Dec 01, 2012 | Samsung Silver 13.3" Ultrabook...
Headphones for a laptop not working
click on Sound
select that!!
hope this helps
Sep 02, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Under device manager where to locate microphone option
Your microphone would only show up under Device Manager if it is a USB microphone. If you are using analog, 2.3mm jack (looks like a headphone jack only red), then you won't see it there.
For WinXP you want to be looking under Control Panel, Sounds and Audio Devices to see and configure settings for your speakers, microphone, etc.
What is shown under Device Manager, if you aren't using a USB microphone, is the sound card. This is because your headphone and microphone ports are connected to the sound card in your computer.
Jul 06, 2012 | Computers & Internet
I have a st69 and every time I record, the vocals while recording sound very chorus like in the headphones, but they sound fine when I listen to the play back, please help.
Check the mixer settings to be sure you are not sending multiple mixes or effects to the monitor (headphone) output. The output used for recording does not necessarily have the identical sound sources and mixing path as the headphone, so make sure the headphone is monitoring the same signal as the recording output.
Feb 07, 2011 | Sterling Audio ST69 Microphone
Pin connections of J8 connector on motherboard for connecting front audio headphones and microphone. I have no idea of which pins on J8 to connect the headphones and microphone as they have never been...
As J8 can vary in usage from circuit board to circuit board, it would be somewhat difficult to solve your issue without knowing the manufacturer, model, & revision # of the product in question. However, chances are that the default settings already allow for front audio input use of headphones & microphone. Also, you should investigate your sound settings within the operating system, primarily, (& the sound settings of whichever software program in question, secondarily). Make sure that you UNMUTE the volume for the front speakers. The microphone should only be taken off of mute in the settings for recording volumes--otherwise the output (speakers/headphones) could loop back through the input (microphone), yielding a reverb effect at lower volumes & a horrible sqelch at higher volumes. A communication programs such as Skype® can help with setting the proper level of volume (gain) for the microphone for optimizing your microphone/headphone experience.
Jan 09, 2011 | Computers & Internet
Headphones w/ built-in microphone. Can both work with one jack?
the simple answer is No. The long answer is your laptop/computers headphone output and mic input are completely separate on the sound card. Meaning there are no tie to the audio in on the heaphone lines, and vise versa on the mic/line in. Sorry to disappoint.
Sep 17, 2009 | Skull Candy Full Metal Jacket Stereo Ear...
No sound from microphone nor headphones
No sound should be coming from the microphone. Its... a microphone. And if you cant get any sound through your heaphones, be sure that you are not plugging them into the microphone port, and into the headphone port or line out port.
Jul 24, 2009 | Computers & Internet
No sound from in-built microphone and sound through headphones
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Nov 28, 2008 | Computers & Internet
Microphone is not working
1-adjust the overall volume by pressing fn+f 5 hotkeys
2-adjust sliding mixer controls by doubleclicking the speaker icon
3-disconnect the headphone jack to enable check of internel speaker.4-confirm that microphone plug is proper connected to mono mic jack.5-confirm that microphone is selected as recording source in control panel----multimedia and recording level is adjusted.
confirm that sound source is selected in control panel----multimedia
confirm that headphone connector connected in right postion
Jan 24, 2008 | Compaq PC Microphone (Black or Beige)...
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
