Question about NAD 218THX 2-Channel Amplifier
Hi my amp left channel does not work. the speaker relee works at both channels and the amp works fine at the right side.it goes not in protect what do u think is wrong ?
  • NAD Master
  • 5,126 Answers
It could be a number of things. Try this test first though. Play some music and swing the balance control to the bad channel and turn up the volume all the way if needs be. If you hear any music breaking in the pre-amp is ok. If not it could be dead. Again if you hear faint music it's the power amp that's not working.
Next have a look inside. You should be able to identify the channels by following the wires from the speakers. Remember that stereo amps are just two mono amps joined. So the Right Channel will act as a guide to what the left should look like. Plus if you are any good with a volt meter provide the correct voltage indications. Any burnt/damaged parts on the left and not on the right is an indication of the fault area. If you have no output from the above test pay close attention to those parts on the heat-sink for the affected channel.
Ignore the power supply parts are anything that is on it's own, unless it's an IC with both channels going into it. As they can go faulty on one channel, but not the other sometimes.
If you can't find anything it might be an idea to replace the left output device(s).
Posted on May 25, 2011
Sony STR-DE875 receiver has no sound from right channel front or back. Checked for loose connections & blew out dust, no change
Hy all. I bought a receiver at last week. But the front speakers not working. The rele is jumping just.
i repaired them ! the rele colour is blue. Three percent . left first -Center, between -Surround, between(right Hand)-Front.
I moved the front channel's rele(right hand) .Katt -it sad. Working, volume is back. Rele specification is (colour Blue) Deg Greatings-Ranger of Hungary.10_26_2012_6_50_16_am.jpg
Aug 23, 2010 | Sony STR-DE875 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
CROWN CE1000- slips into fault immediately after connection
if ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Apr 05, 2010 | Crown CE1000 2-Channel Amplifier
Denon 1906 all the right channels speakers not working
when turn on the amp,the volumn cannot under control
Oct 10, 2009 | Denon AVR-1906 Receiver
Hi i have an audio source 300 watt amp with a&b speaker outputs. the problem is that no sound comes from the left side outputs a or b. the right side works fine thank you mike
You have a blown channel. If you are experienced with electronics repair, use the right channel to assist in diagnosing the left. Both channels should be efectively identical. In most cases, the defective parts are the output transistors. You should be able to A/B the output amp sections.
Let me know if you need further assistance.
Dan
Jan 14, 2009 | Audio Players & Recorders
How many speakers can I use?
This should work if channel 3 & 4 are bridged at 4 ohm.
channel 1 should be stable at 2ohm
channel 2 should be stable at 2 ohm
You can hook up the right side speakers together ( + with + and - with - ) . same thing with the left side. this will give you 2 ohm each channel. this will cause your amp to run hot (this might be tuff on the amp). It will give you right (2 speakers) and left ( 2 speakers ), no front and rear adjustement if you need to balance your sound. I think you should be better buying another amp for your sub and take your 4 channels for your 4 car speakers. this amp as a rca output that can feed the other amp ( sub amp ). it is possible to do it.
Good luck
Nov 11, 2008 | Alpine MRP-F250 Car Audio Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Left channel not working
The first thing I would check has already been done, the only other thing would be fuses. I am preety sure there is a protection fuse at ever channels output to protect against a dead short. I am sure you have already fixed this problem but I thought I would give it a try. Let me know what you found.
Jul 13, 2008 | Denon AVR-3802 Receiver
Only one sub works
The amp should produce no output when using the left negative and the right positive.
If the amp works bridged (left positive and right negative) with one speaker AND works when you connect one speaker from the left positive to the right positive, it would appear as though the right channel isn't getting any signal.
Try inserting only the left signal cable (nothing plugged into the right RCA jack) to see if the right channel will work when a speaker is connected to the right channel speaker terminals.
Jun 30, 2008 | Sony XM-2002GTR Car Audio Amplifier
Help
I recommend you swap your left and right input cables to make sure it's not a source issue.
So from your headunit, plug the left channel output into your amps right input and your right channel output into your amps left input.
If the same side is still not working then disconnect both (or single speaker if it bridged) the speakers from the not working side at the amp. Connect the front and then the rear speakers individually and retest to see if one of them works.
If one does work then check the cabling and speaker connections on the one that doesn't. If it's shorting out anywhere it will stop your amp from powering that channel.
Failing that, it could just be that your amp has partly failed.
Feb 15, 2008 | Boss Riot 1500D Car Audio Amplifier
NAD 218THX 2-Channel Amplifier Logo
422 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
