Question about Refrigerators
Compressor gets hot and stops cooling - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 20, 2011
Why has my freezer stopped cooling ?
The freezer does not get cold the evaporator fan motor might have stopped working.
http://thesisreviewadvisor.com
Jan 08, 2015 | Refrigerators
Should my refigerator compressor be hot to the touch?
Hello friend, thanks for the post!
Based off the information you have provided your compressor can be hot to the touch because it is working to help cool down your refrigerator. I would allow it the opportunity to maintain proper temperature inside of your appliance before it stops running. I hope this is helpful. -Matt
Sep 23, 2014 | Frigidaire Refrigerators
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Switches off after 5 mins
Thermostat click? A leaky pressure switch will cause this.
Stuck fan, causes compressor to get hot and stop.
Dirty coils, ditto.
Blocked outside vents, ditto.
Weak run capacitor, will cause compressor to run hot and stop.
Low voltage from bad breaker, house wiring, outlet, cord or internal switch, will make compressor run hot.
Low on gas, the circulating gas keeps the compressor cool and will overheat quickly if it's too low.
Have a professional check, pretty much in that order even.
Apr 01, 2014 | Heating & Cooling
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Cabinet flanges and mullion very hot to the touch and not cooling at all, model ed25qf
turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
May 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Gold Whirlpool 25.3 cu.ft refrigerator stop working
if the compressor is very hot then it can be possible that the compressor is getting faulty,but also other possibility can be the compressor relay.if the relay beside the compressor is got faulty then the compressor gets over heated.so first unplug the unit from main power outlet and then remove the relay and check it with continuity to confirm the fault.is it relay or compressor.
Aug 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
