Question about 2wire HomePortal® 1800HW Router (1000400212000LNR)
2WIRE HOMEPORTAL 1800HW WIRELESS PROBLEM
LOST RANGE ON WIRELESS ON LAPTOPS USING VISTA CALLED AT&T THEY CHARGED ME 55.00 AND TOLD ME THE PROBLEM WAS FIXED STILL CAN'T HOOK UP TO WIRELESS MORE THAN TEN FEET AWAY. USED TO GET 30 FEET USING SAME SETUP
Went back to the earliest version of driver for the network/wifi card built in the laptop and i got a hookup with decent range.
Posted on Aug 20, 2008
SOURCE:
I am trying to access the 2Wire router with another wireless computer (Vista) and all it will do is give me a "limited access" which does nothing for me. I have been using this set up for over 1 year with...
you said you are using vista.. Try optimizing your browser..
And restart the modem..
Check if the plan you have is the one that is causing the connection prob. contact your internet provider
Nov 10, 2009 | 2wire HomePortal® 1800HW Router...
Will a netopia 3-d reach wireless adapter work with my 2wire 3800hgv-b router from u-verse?
if you are wanting to run stricktly wireless then no if your router is not wireless ready. If it only has wired connections and not wireless capable you will have to be wired into it using a cable.
Oct 17, 2009 | 2wire HomePortal® 1800HW Router...
For 2wire HomePortal® 1800HW. adaptor broadband connection ... I recently upgraded from my 2wire DSL to Uverse. ... Linksys wireless adapter won't auto connect to 2Wire. ... I thought to use it as a...
First thing to do here is to reset the unit by pressing the reset button for 30 seconds while power is ON , after that if still the same better to contact your ISP or the manufacturer of the device and have it replace..
Sep 08, 2009 | Linksys Wireless-G Broadband Router
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
2wire portal router, after year of wireless connect, stopped
it could be that the wireless part of the unit has failed but to test, can you make sure and try while sitting very close? Also, check for any new appliances close by causing interference
Jul 08, 2009 | 2wire HomePortal® 1800HW Router...
I recently upgraded from my 2wire DSL to Uverse. My older laptop with the 2wire card and the home portal fins the new network but only runs at 11 mbps. Where my other laptop with the newer 2wire software...
That means the older 2wire card was a B model adapter, which can only run at 11mbps. The other laptop most likely has built in wireless or some other adapter in it that runs on the G model, which is 54 mbps. There is no way to fix this issue, other then aquiring a new wireless adapter for your older laptop.
Jun 29, 2009 | 2wire HomePortal® 1800HW Router...
I cant get my laptop to connect to my 2wire how do I do this
Connect to the router from the desktop and enable wireless.
if you have windows XP
Click on the start menu, go to run
-> in the run prompt type: ncpa.cpl
--> right click on you wireless network connection, go to the wireless network tab, removed your network from the list of prefered networks
---> now try to re-connect
if you have windows vista
click on the start menu, go to the control panel, look for an icon called network and sharing center (switch to classic view if you don't see it), then go in the tasks to "manage wireless network connections" and remove your network from the list using the green minus sign button
Dec 17, 2008 | 2wire HomePortal® 1800HW Router...
Can't get my netgear PCI Adapter connected to my 2wire 1800hw broadband
You will need to modify the router configuration rather than the adapter to setup port forwarding. Normally Network Address Translation (NAT) will allow most of your services to connect without issue.
Nov 06, 2008 | 2wire HomePortal® 1800HW Router...
Unable to access homeportal, but internet is ok?! (2wire 1800hw)
I had the same problem. I reset the home portal to factory setting and uninstalled the 2wire software from my main computer. I then reinstalled the system using installation cd that came with 2wire.
Jan 21, 2008 | 2wire HomePortal® 1800HW Router...
2wire HomePortal® 1800HW Router (1000400212000LNR) Logo
113 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
