Flashing cursor - HP 6710b vista laptop Hi, Ive got a HP 6710b laptop with a flashing cursor and a black screen. Tried the vista repair disc to restore and do a a startup repair and reset bios to defaults and still no good. I dod not have a backup of the vista on the hd or disc. Any ideas? Thanks
  • fffdads f\sdf May 20, 2011
    Hi, Thanks for your comments, but I'm still having problems.
    As I mentioned Ive already reset the bios to defaults with no effect. Also in the bios there is the facility to do a hard disc and memory check which Ive done and both pass with no errors, sos I think this says the hd is connected correctly...
    Boot order is correct with notebook HD set to 'first'. If I boot from the vista recovery cd this runs fine and I've successfully done a restore with no effect and also start up repair.
    Its looking like I need to wipe the hd and re-install vista except I dont have a copy!!
    Any more ideas????????
    Thanks.....
    Guru:
  • 868 Answers
Hi yancart,
I see that you are having issue booting into windows on your machine and that you are getting black screen and a blinking cursor.
The issue you are experiencing can be a Hard Drive issue not being detected on the machine or possible something else is wrong with the system to be able findo ut we try doind some steps to check the machine.
>First turn the Machine OFF.
>Turn the Machine ON again then Keep on tapping F12 on your system to boot into the Boot Menu, or if it shows on the screen Press F11 Boot Menu then you should press F11 if your system uses F11 but in regular machine F12 is the Boot Menu.
>Once you have the Boot Menu Screen it should give you options from your Hard Drive to the DVD drive on your machine.
> Select you Hard Drive it should be the first on the list highlighted in Blue then press Enter on it to boot into your Hard Drive.
>Check if this will boot into your Hard Drive if it does not then, possible your Hard Drive is nto detected.
>If you can try to reseat your Hard Drvie from the machine just to see if it went loose, then try restarting the system again and see if it will boot into windows.
>If still the system will still not boot into windows then try setting the BIOS to defaults then restart the machine agian if still the issue is the same then most probably your Hard drive may need replacing.
Posted on May 19, 2011
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
Hi, when I turn on the Acer Aspire 5920, the acer screen comes on, the bar across the bottom moves, then it goes to a blank dark screen with a blinking cursor. I have tried turning off and turning on and...
Check if your hard rive indicator light is flashing (has disc shape icon or can shape icon next to it). If it is then put in your windows disc and do a startup repair. Make sure it is booting from the disc drive first. if it isnt flashing then you may have a dead hard drive. Try taking the hard drive out and putting it back in.
Mar 19, 2011 | Acer Aspire 5920-6727 Notebook
I have a acer extensa 5235, running windows 7 pro.the problem started when i was playing an game of golf on it. a box come up and it said the next course could not be found. then the screen went black...
Your computer's operating system just crashes down. What you can do is to do a start up repair. You need the operating system discs which came with your computer during the time when you bought it. It says windows 7 installation/operating system.
Here's what you need to do.
1. Insert the windows 7 operating system disc in the dvd drive.
2. Restart the computer. It will bring you to a page which will ask you to press any key. Just press any key to boot to the installation cd.
3. A blue screen will appear and it will bring you to the page which has the option to install or to repair. Select repair.
4. Then follow the on-screen instructions and finish the process until it restarts.
5. If it does not fix the problem, you have to do a complete/clean reinstallation.
I am providing you a full tutorial on how to do it. Click on the link below so that you will be directed to the link.
http://www.techtalkz.com/windows-7/514412-windows-7-installation-guide-tutorial.html
Thank you for using fixya,
Carlo
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Feb 03, 2011 | Acer Computers & Internet
Screen is black with flashing cursor
Try to make sure that the first boot is set to CDROM.
May 02, 2010 | Fujitsu LifeBook C2330 Notebook
I was trying to restore to factory settings. Now screen is Black background & has Windows/RM> and cursor is flashing how do I get past this point to restore
Restart your computer, press F8, advanced boot options menu will be seen.
1> Select REPAIR and then STARTUP REPAIR.
2> If it does not works then again restart your computer and press F11. Use the internal recovery partition to format the windows partition of your hard drive by selecting SYSTEM RECOVERY.
3> If it fails to solve again, use your or order a set of RECOVERY DISCS for your system.
It will solve every issue............
On faliure again, contact HP support centre, or your nearest HP/Compaq service centre
Mar 27, 2010 | HP Mini 1000 Netbook
I have a DV9000 whos screen goes black immed after power up
try to press F8 continuously before the microsoft image until you get different options. select "Safe Mode" on the options using your UP or DOWN cursor keys then hit ENTER. if it works and boots up then you can use the windows operating system disc to repair it. if it still does the same thing then you might need to reformat and reinstall the windows vista operating system...
Nov 08, 2009 | HP Pavilion dv9000z Notebook
Gateway mseries laptop won't start, screen black with flashing cursor in top left corner
It's flashing because it's trying to load via the hard drive.
What have you tried so far?
Safe Mode, boot cd, etc?
Jun 19, 2009 | Computers & Internet
Compaq Presario R3000 Black Screen with flashing cursor
Lines are the BGA RAM Or VRAM Needing rework.. This will also cause boot issues on these models. Do you ever see the Compaq Logo? Weve repaired a ton of these and class settlement happened for the R3000's regarding the jacks but we could repair the other issue as well. (As well as install a new jack while its here).. HP's reimbursing for these outside repairs.
Feb 01, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
