Question about Motion Computing Motion LE1700 Tablet PC Centrino Duo Intel Core 2 Duo L7400 15GHz 121" SXGA+ 2GB DDR2 SDRA
My power slide button on my motion LE1700 does not power up my tablet, this is my second one this has happened too. I have sent if off for fixing and last time they charged myself 400pounds for a complete mother board change. It feels like the spring behind the slide switch has come loose or something. please can you help
    Scholar:
  • 88 Answers
Those are generic B.S. answers. The power switch is a flat tab that has two prongs on the rear side that interface a very small slide switch on the mother board. The mini slide switch has a plastic piece that sticks out about 3mm and the plastic part is unfortunately not very strong. the slide return spring may have become detached as well- this indicates major trauma to the slide switch in some way- and the repair is expensive because the parts are not readily available- hence the 400 price tag for a whole new board. Nowadays these tablets are dirt cheap. I'm guessing by how old this post is you have moved on to a newer tablet- if not I'll work with you to get it fixed- at a lot less as well.
Posted on Sep 07, 2014
3 Suggested Answers
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
  • 60 Answers
SOURCE: computer gets stuck when unplugging/plugging
You may need to re-install the os
Posted on Feb 26, 2010
Show me how to restore my tablet to factory settings?
Hi Anonymous.
Looking about, the manual for this system
https://www.motioncomputing.com/downloads/User_Docs/LE1700/LE1700UserGuide_vista.pdf does not talk about how to reset the system. There is mention of a reset for a CL900 system by pressing the SAS, Battery Status, and Power buttons at the same time
http://support.motioncomputing.com/kb/KnowledgebaseArticle10597.aspx?Keywords=LE1700+Reset I can't verify this will work on the 1700.
Your most direct answer may come from calling the Motion Computing technical help line:
1-866-322-9783, option 9.
7am-8pm M-F CST
Good Luck!
D
Nov 23, 2015 | Motion Computing LE Tablets & eReaders
LE1700 can't connect to internet
Try resetting your internet modem and wireless router by unplugging them wait 30 seconds then plug in modem let it boot then the router. You can also try restarting the tablet and see if that helps.
Feb 08, 2014 | Tablets & eReaders
My visual land tablet is frozen on the lock screen, it want slide to unlock the screen, what should I do
follow this steps and fix it. GOd bless you
Press the power button. Hold it for 20 seconds to force the unit to shut down.
  • 2 Turn the Tablet back on to determine if it is still frozen.
  • 3
    Remove the power adapter or USB cable from the Tablet. Turn it back off. Turn the Tablet over and remove the screw from the back of the device. Slide the battery panel off of the Tablet and pull the battery out of the unit.
  • 4
    Connect the Tablet to the power adapter and power it on. The freezing issue should be fixed and your Table should respond properly. Reinsert the battery and charge it to full before removing it from power.
  • Read more: http://www.ehow.com/how_8722116_troubleshoot-frozen-nook.html#ixzz2aUBnGy3w
    Jul 29, 2013 | Tablets & eReaders
    Don't know what Enter HDD Password means?
    It means that you must enter a password to access the Hard Disk Drive
    May 01, 2013 | Motion Computing LE1700 (EB844523252)...
    Hard drive disappeared
    this is a common problem on these le1700's. Can you hear the micro drive spinning up when you turn on the tablet? If you hear clicking the drive may have gone bad. If the drive is heard spinning up and doing normal whirr's and clicks it may be the connectors need to be reseated on the drive. Opening the panel for the drove and removing the 4 screws allows you access to the drive and the delicate ribbon cable attached to it. Carefully reseat the drive, or have a person that knows about zif (zero insertion force) drives reseat it for you. If it's still not working it's possible the cable itself went bad. ONLY OEM cables seem to work on these- the aftermarket ones are iffy. Also they type of drive seems to be important as well- Toshiba or Hitachi micro drives are o.k., but a micro ssd ziff seems to have less compatibility issues in my experience.
    Apr 17, 2013 | Motion Computing Motion LE1700 Tablet PC...
    LE1700 Tablet PC DOES NOT POWER UP
    Some illegal software,software viruses or some other reasons make android system malfunction, and it can't working. Brushing the firmware can be used, and different tablet pcs have different methods. you can download the firmware in the internet and do it follow the instruction.
    Apr 02, 2013 | Tablets & eReaders
    Motion LE1700 Tablet PC repair
    If the tablet is turning on, but not booting into your os then there is most likely a problem with the hard drive. If the computer doesn't turn on at all then the battery or charger may not work.
    Apr 02, 2013 | Motion Computing LE1700 Tablet PC
    My motion computing battery light is not on and the machine won't start
    Hold down the power button for 10 seconds then release. Then try pressing the power button again.
    Apr 26, 2011 | Motion Computing J3400 Rugged Tablet PC...
    Motion Computing Motion LE1700 Tablet PC Centrino Duo Intel Core 2 Duo L7400 15GHz 121" SXGA+ 2GB DDR2 SDRA Logo
    Top Motion Computing Tablets & eReaders Experts
    jason
    k24674
    Chris Larocque
    Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
