Question about Philips Car Audio & Video
I have a Radiosat 6010 and have made a cable that plugs directly into the back of the radio where the cd changer would normally be plugged with a 3.5 jack on so that i can plug my mp3 in but when i try to change the source on the radio to cd changer mode it just beeps at me. In order for it to work i need to be able to put the radio in cd changer mode. Any idea how i can do this or trick the radio into thinking that there is a cd changer attached? Cheers
TRocky
  • 4 Answers
SOURCE: Ipod Connection through RCA Cable
Actually, what I think gbaity is doing is utilizing his IP(Interactive Pioneer)-Bus port in the back of the DEH-P3000, which is an input port designed to allow the deck to use an external multi-disk CD changer. All you need is the CD changer, then change the input source from your deck to "M-CD". There are folks on eBay and other places that sell a cable that pluggs into that very same port. They are designed to allow the unit to accept input through the IP-Bus from an ipod or just about any low-level input that you can pass through the RCA jacks. I have the same deck, and also just purchased an ipod cable for the IP-Bus, and it also does not work. I have been told that I need to switch the "M-CD" input source to "AUX" as the input, but I do not know how to do that. pressing the input source button only displays "CD", "M-CD", and "FM/AM". Does anyone know how to add "AUX" to the choices or otherwise show us how to make these cables work? Thanks - TomR
Posted on Sep 23, 2007
micromaster
  • 3614 Answers
SOURCE: CDX-CA600X Audio in sockets
Ok.. i got the post, please wait while i look into the details on the cd player that you have there...
Thanks
I will post in here again
micro
Posted on Jul 16, 2008
HitWizard
  • 67 Answers
SOURCE: aux input for sony car stereo (cdx c 5000r)
For Sony Stereos, you will need to get what is called a Bus Converter. The RCA ports you are trying to use are for a CD changer or alternate device like satellite or HD radio, and those have to have some sort of frequency signal to even be selected. You can find a Bus Converter that will allow you to use this as an Auxiliary input. The device you are looking for is called a Sony XA 300, and it will allow you Two extra Aux Inputs, I believe.
Posted on Jan 29, 2009
SOURCE: Sony XR-C350 Car Stereo - can't use cassette adapter for ipod!
I have a Sony car cd playerXR-c350 with a ten Cds unit,I want to know if there exist a Cd mp3 music player to use instead of the cd player, thanks.
Posted on Mar 20, 2009
  • 5 Answers
SOURCE: Hook an ipod to Pioneer DEH-16
The RCA jacks on the rear of the head unit are rear pre-amp outputs. (google it if you need an explination on what purpose they serve or see the installation guide) With that said, I am able to play my mp3 player through them but since they are 'rear' pre-amp outputs my mp3s only play on the rear speakers. see this post for more...
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=45149&query.id=194369#M45149
installation manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/35572505Installation%20Manual%20DEH-1600.pdf
owners manual:
33399012operation%20manual%20deh-1600.pdf
Posted on Mar 25, 2009
Can someone help me find my radio code?
Does this help?
http://www.radio-code.co.uk/philips-radio-codes.html
Apr 22, 2014 | Office Equipment & Supplies
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
Code for renault radiosat 6010 7700433072 x847 philips 22DC461/62L 9022 214 61624 PA4Bis ,4*15W,RDS CD changer control FD10 99 21 4201367 MODEL NO:22DC461/62l PROD NO: FD 1099214201367
Try code 2159
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct first digit
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬ ] button for up to 10 seconds to store the code
Sep 14, 2009 | Electric Renault R26 Radio Control Car
Code renault radiosat 6010
Your code is 6359
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Sep 11, 2009 | Electric Renault R26 Radio Control Car
Code for RENAULT RADIOSAT 6010 7700 433 072
Please post the 14 character Serial Number beginning with RN ************
...usually found stamped in the metal casing.
and also the SECURITY NUMBER in the format TOA123 or TA123 or just A123 found at the end of a carcode.
Aug 18, 2009 | Electric Renault R26 Radio Control Car
Code for RENAULT RADIOSAT 6010 7700433074 PHILIPS 22DC461/62E 902221461622 PA4,4*15W,RDS CD changer control FD1199282300460 model no:22DC461/62E prod no:FD1199282300460 code gravage 2300460
RENAULT RADIOSAT 6010 7700 433 074 PHILIPS 22DC461/62E 9022 214 61622 PA4,4*15W,RDS FD 09 98 41 2033067 MODEL NO:22DC461/62E PROD NO: FD 099841233067
May 14, 2009 | Electric Renault R26 Radio Control Car
Bluapunkt IDC-A09 Not playing
That is probably a dirty lens problem, try first cleaning the lens.
Feb 28, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Help
Sorry my friend, JVC does not see that model number. Is that the changer number or the radio's model number? I need the radio numbers
Jun 08, 2007 | Jensen XCH6RF 6-Disc CD Changer
Car Audio & Video Logo
184 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
