Question about Amcor Heating & Cooling
Compressor engages for 3 seconds then shuts off then later does it again. Is there a safety system or relay switch associated with the compressor engaging?
  • Amcor Master
  • 43,501 Answers
The compressor is trying to start but cannot so the overload kicks it off...
The start relay and capacitor maybe bad if it has those parts... even so the compressor may also be bad...
heatman101
Posted on May 19, 2011
I changed the ac compressor and dryer pumped it down and charged the system the compressor comes on for 3 seconds and cuts off. The clutch does not stay in gage. What could be the problem now?
Sounds like it's shutting off due to high pressures in the system. Do you have gauges to read the system pressures? One thing that would cause this is too much freon in the system, or too much oil. Did the compressor come with oil in it or did you add oil to the system? Too much oil and/or freon will give high pressures and the high pressure switch will shut the system off. Or the high pressure switch could be damaged, maybe even unplugged is a possibility. If it is plugged in you could try unplugging it and seeing if the compressor keeps running for longer than 3 seconds, if it does pressures might be too high. It could also be a bad relay getting hot and kicking off. Try switching relays and see what happens. Another possibility is the low pressure switch but not too likely in this case.
When the compressor shuts off, can you turn it by hand? If not, high pressures or even a bad compressor are possible.
Lot's of possibilities. Just have to wade through them. I'd start with the relay and then check the pressures.
Good luck.
Jun 21, 2014 | Cars & Trucks
1999 Cadillac Deville - ac blows hot - first thought was charging but when I hooked up gauge read fully charged (actually, slightly over charged) - compressor kicked in for one second, then shut down -...
Do you have any stored codes in the computer ? If a problem occurs that could damage the compressor, the computer will deactivate the system until the problem is fixed and the codes are erased.
May 17, 2013 | Cars & Trucks
My a/c compressor is only blowing hot air when I turn it on. I know a little about cars so I know it's the a/c but I am not able to find one on any site that may sell used or new.
If all you get is hot air there are several possibilities. The compressor is driven by the serpentine belt and is engaged and disengaged by an electric clutch mounted on the compressor drive pulley. With the engine running, have an assistant turn on the AC while you observe the AC compressor clutch. If the clutch engages, you can be reasonably sure that the system has freon, and the electric circuit is OK. If the clutch doesn't engage, which is the most likely situation, either you are low on freon, the AC clutch relay is inop, or AC compressor fuse is open (blown). A search of Google images will give you the location of the AC relay. You can pull out the relay, carefully remove the cover, reinsert the relay, and engage the compressor clutch by manually closing the relay contacts. Warning: do this only for a second or two in order to see the clutch engage. If the clutch does engage, then you are probably low on freon. There is a safety switch that prevents the clutch from operating if there is not enough freon in the system. Hopefully, this is the case. Go to Walmart and get two cans of r-134 and the inexpensive kit, and following their instructions, charge your system. If this is not the problem, you'll need a set of AC gauges and the skill to use them. Hope this helps. Dano
Aug 31, 2011 | 1998 Lexus Gs 400
If I strap terminal 3 to 5 on the compressor relay the compressor comes on. What controls the compressor relay?
THE LOW PRESSURE SWITCH
SYSTEM IS PROBABLY LOW IN FREON
TO CONFIRM LOCATE LOW PRESSURE SWITCH AND JUMP
THE TWO PINS IF COMMPRESOR ENGAGES THR SYSTEM IS LOW
DONT LEAVE IT JUMP YOU WILL BLOW UP COMPRESSOR
NEEDS FREON TO CARRY COMRESSOR OIL TRUE OUT SYSTEM
May 07, 2011 | Chevrolet Lumina Cars & Trucks
AC does not work. Compressor will not engage Blower only blows on high speed. Is the two a related problem? Where should I look to solve the problem
The most common reason for the compressor not engaging is low refrigerant pressure. The ac system has a safety switch that will not allow the compressor to engage when there is not enough refrigerant pressure because the the refrigerant carries the compressor lubricant throughout the system. Have the system checked for proper charge. You probably have a leak. The fan is probably a separate issue.
Jun 19, 2010 | 2002 Ford Taurus
Compressor relay not enaging sometimes and seams to cycle to often changed relay worked for about 8 hrs could not get voltage reading when it failed to engage but every few seconds a very light attempt to...
If you have a low pressure switch in the system, then your compressor relay or contactor is cycling, do, to the low pressure switch. In an R-22 system the setting on the low pressure switch is approximately 60psig. Any time the pressure goes below 60 psig the switch will shut the compressor off. This is to protect the compressor if you get a leak in the system or if the blower quits or your filters or coil get real dirty or plugged up. If your blower is running fine then you need to check the filters or coil to see if they are dirty or plugged, if not then you are low on charge.
Oct 13, 2009 | Heating & Cooling
1996 lincoln towncar. No a/c compressor engagement unless jumped
the control unit is no good.i had a similar situation with a 98 tracker,and installed a switch to give it a ground for the compressor relay that comes from the a/c computer module.
it works good and goes on and off with the a/c switch.
Jul 18, 2009 | Lincoln Town Car Cars & Trucks
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Compact refrig not cooling
Hi!
It is due to multiple reasons, compressor and relay of the compressor being the most common. Is the fan working?
Feb 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
Fan runs, but when compressor starts to run, you can here it trying to start up but then falls off and 30 seconds later it tries again and falls off again. It does not kick the breakers out. Duo Therm...
The compressor has a safety switch under the cover where the wires connect to it. That's what is kicking out. You should check the capacitor connected to the start winding. Check the wires where they connect to the compressor. A burnt off wire for the run terminal will cause these symptoms. If that's all good, it's being fed correctly on all 3 terminals, the compressor has stalled and will probably never start again. You can try a "hard start" kit, but not on a Scroll compressor (read the label). They aren't designed to survive that.
Jul 27, 2008 | Heating & Cooling
Heating & Cooling Logo
629 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Bill Long
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
