Question about NAD C542 CD Player
Nad cd541i doesn't always read cd's; it can tell me how many tracks/minutes there are but won't find the beginning of the cd; in this case, sometimes if I skip forward two or three tracks and then go back to the first track, it will start playing; is there a simple solution to this problem, which makes me feel that a $500 unit is being disabled by a 25cent piece of plastic somewhere
    Brigadier General:
  • 8,546 Answers
It sounds like a physical problem in the laser seek mechanism. Possibly a sticky area on the guides. Heavy reading for all malfunctions related to optical disc...
http://www.repairfaq.org/sam/cdfaq.htm
Posted on May 19, 2011
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
Hi, I have a pioneer DEH-P5500MP which always worked just fine but now when there is no cd in the radio it won't play so i try the source button but that doesn't work so i put a cd in and it starts...
It sounds like you may have a bad switch. If you have a multimeter you can check the switches for resistance. If the reading on any of the switches is less than a few megaohms it is probably bad.
Oct 30, 2011 | Pioneer DEH-P5500MP CD Player
Hi, I have a NAD C541i cd player when i turn it on i get three blue line on the display, i open the draw and insert a CD disc but the blue lines stay on the display and the disc don't play. can you...
The blue lines you mention should flash when trying to find
the 'Table of Contents' of your CD, even if a CD isn't loaded.
If when a CD is loaded and these lines flash for a while without
any CD info e.g track no. / disc length then it's more likely that a problem has occurred with the laser.
Various NAD CD players use the Sony KSS-213 Laser unit
and for some reason particularly with NAD CD players, they tend
to drift out of calibration over time so what i usually do when i come across this is very finely adjust the pot trim on the laser itself and testing a CD between adjustments.
Jun 22, 2011 | NAD C541 CD Player
Second hand NAD player worked well at test. Arrived at home no reaction when power on. Led turns first green, then orange. Doesn't react at all...
If it's the C541i version then there should be a switch on the rear of the
unit.
Flick this switch and all should be fine.
I think it's something to do with interconnecting other NAD products
why this switch is used.
Jun 03, 2011 | NAD C541 CD Player
Hi Skipping problem with a NAD C545BEE, plays OK for 1 minute, then skips randomly wthin the track, then will skip to different tracks on the CD, like fast forwarding. No problems with the disc themselves
hi
There is a diode in the power supply which gives dc supply to the laser focusing coil driver ic . if the diode get faulty this problem can occur. Just replace all the rectifier diodes in the power supply stage. Its better than searching for the exact one. then check the cd player is it skips the tracks. if then also its skips the tracks then you have to change the laser pickup unit.
ok
May 19, 2011 | NAD C545BEE
CD input cuts out intermittently
Can be that the CD disc is jumping on vibration, the optical head is defective and not reading the tracks or if the line to the amplifier is having a loose connection in the wires or within the RCA jack socket.
Play Cd when car is in stop , if in motion check the wiring and CD for errros.
if interuption always from the disc then the optical head can be faulty
Sep 16, 2010 | NAD C162 Amplifier
NAD T531 - reading problems
Try taking the outer casing off and manually cleaning the laser lens with alcohol , this should work for you.
Aug 13, 2009 | NAD T531
Nad cd player cd541i noise
Hi...
That one is going to need Tech service.
I've worked on several of the NAD players.
Sounds like a focus or gain adjust needed.
Feb 14, 2009 | NAD C521 CD Player
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
Won´t read any Disc
I have the same problem since the early beginning after purchase. I'm very upset with NAD for the zero-value technical service in Italy. After 2 months they gave me back my C541 with new defects (the tray now doesn't work properly). They have tried - they said - different optics without fixing the problem. Does anybody know if a compatible optic / tray exists?
Thank you
Marcello
mcl.vlb@tiscali.it
Sep 25, 2007 | NAD C541 CD Player
NAD C542 CD Player Logo
350 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry Stiles
Larry Stiles
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
