Question about Sabrent External Floppy Drive
I get message "Disc is write protected" when it is
  • Sabrent Master
  • 27,725 Answers
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Posted on May 20, 2011
Trying to reload Windows OS. Run into
From another computer build a msdos floppy disc, yes floppy disc.
I believe you computer accepts floppys does it not? and i also asume you are running xp, you can try running the startup disc and trying to check disc, but if you cannont procede, i would opt into downloading another copy of the windows and try installing through that method. If the disc dosent load, and you get that error message of the bat, another step will be waiting for you.
May 26, 2012 | Dell Dimension 8400 PC Desktop
I have original eyewitness encyclopedia space universe cd. but when i install it a error message shown in the computer. "[1058] the sound decompression software has not been install properly. please...
Hi ,
This product is not compatible with Windows 7 but it should run under Windows XP . If you are running under XP , I suggest you delete the program , reboot your machine and reinstall the program under Windows XP . If it still fails , you could need to reinstall Win XP or use the recovery disc . Launch the disc , select " install a new version of XP " and choose " repair " when you'll be asked to .
Make first sure you have installed SP3 and tested your program with XP fully updated .
Best regards ,
fanaudi .
Apr 22, 2011 | Dk Multimedia Eyewitness Virtual Reality...
I wiped my hard drive using kill disk. I have a Windows XP home disc to install the operating system, but when I boot the computer, I get the "Error loading operating system" message and it won't...
when you boot the laptop, if you don't see a message that says press any key to boot from CD, your boot order is wrong.
Check your boot order, when you see the splash screen (logo) look for a message that says press a F1-F12 key to change boot order or if that message is not displayed, press the key to enter setup.
Look for an option that list boot order and shows your hard drive, CD/DVD and USB options.
Move the CD/DVD item to the top of the list and try again.
Feb 11, 2011 | Gateway Computers & Internet
When I try to open my program I receive the following message, "Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for this application...
Please restore your system , In previous state
Please follow the bellow links,
System Restore WIN XP systemrestore2 Backing up-System Protection and System Restore in Windows 7 Windows XP System Restore Is Easy to Use Use System Restore to Undo Changes if Problems Occur Using System Restore in XP - How-To GeekHope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 25, 2011 | Microsoft Streets and Trips 2008 for PC
I haven't had a recent hardware or software change but when I turn on my Dell Inspiron 1521 laptop I get a black screen with the following message: Windows Boot Manager Windows failed to start. A...
boot from an applicable boot disk & use fixmbr to repair the boot sector,
OR have you tried safe mode or last good....( you need to press F8 seconds after the PC is turned on)
Dec 31, 2010 | Dell Inspiron 1521 Notebook
Error message at start up. Running windows xp. HP Pavilion a700N PC desktop. The message is: This application has failed to start because hpzjrd01.dllwas not found. re-installing the applicationmay fix...
To fix hpzjrd01.dll errors occurring due to corrupt or incomplete installation of HP printer software, uninstall your printer driver and reinstall it again.
To ensure the HP printer software is completely uninstalled from your system, we recommend you either use the built-in Add or Remove Programs utility or use the help of a third-party uninstaller, such as Perfect Uninstaller.
for more information and help click here hope this helps you.
Thanks
Michel
Dec 18, 2010 | HP Pavilion A700N (PJ516AA) PC Desktop
I saw the message while copying even a single file from my external USB HD i-e "the request cannot be performed because of device I/O" and "digital delyed right failed" simultaneously...
Is the error occurring when reading "from" the W.D. drive,
or is the error occurring when writing "to" your internal drive?
Is that the exact spelling of the error-message?
Nov 17, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
Hi there! Yesterday I was installing Windows XP
Sorry to hear your having issues installing the OS.
There is two problems your facing one is the disk is so scratched that the system can not read the disk or the hard drive has bad sectors or clusters which are failing when being written to.
You have two options to fix this one is to make sure the cd is clean an or replace your hard drive.
General disk read error message tend to be from hard drive cylinder's.
Nov 05, 2010 | ASUS Computers & Internet
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Windows xp setup halts
This generally indicates that the disc is corrupt. It can be anything from a scratch, degraded read section on the disc, or a distortion from the disc getting bent or hot (left in direct sunlight). You will most likely have to use a different disc for the install.
Sep 03, 2008 | Toshiba Satellite A65-S126 Notebook
Sabrent   External Floppy Drive Logo
189 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
WTF Chuck.....
WTF Chuck.....
Colin Stickland
Colin Stickland
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
