Question about Ovens
Lighting is gone out on the front panel display.
  • 407 Answers
You will have to remove the front panel.It is inside there.It should have screws on the side.
Posted on May 19, 2011
  • bdf5 May 19, 2011
    Duhhh !
  • Michael Spreafico May 20, 2011
    Well I could tell you more,but I have no idea what stove you have,how old,no model number,no nothing.So ...Fill in the blanks.
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
F2 shows on display on whirlpool gas stove
Keyboard Failure
Error Code: F 2
Component:
To localize the fault - disconnect the switches from the display unit. If the fault is gone - replace the switches.
Touch buttons - replace control panel assy
Tactile switches - replace control panel assy
Dado
May 14, 2014 | Whirlpool RBS305PDS Electric Single Oven
Stoves E2H600- lighting behind fascia panel has gone off so cannot now see what temperature settings are! How do you remove the fascia panel to access and replace defective lighting unit/s? Many thanks,...
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
Jun 22, 2011 | Stoves Ovens
Front panel light is fading
Had the same problem. Replaced the display board.
Apr 12, 2010 | Thermador SC302T Electric Double Oven
LED display stopped working
Hi!!! your clock or control board has malfuction.You can get access from the back of the unit pull the unit out and look at the back remove the screws..Your control board clock board went bad..Good luck..
Jan 04, 2009 | Belling XOU252 Electric Single Oven
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Lighting panel in my electric Thermadore double oven is dim.
The cap replacement worked....saving $250 (every 2 years !!!) I posted it on another site...now its making its way around the web....its the only value added thing I've done on the web (sadly!).
Nov 14, 2008 | Thermador SC302T Electric Double Oven
Ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
Jun 29, 2008 | GE ZSC2001FSS Advantium Electric Single...
Front display does not light up
I experienced the same problem. Order a control panel piece and replace it (the clock panel -is what it is referred to on parts list). It is a matter of killing the electrical power, unscrewing the contro panel, unplugging the old panel and plugging in new panel. Takes all of 8 minutes to do. I am a woman and did it myself. Got tired of waiting for the man to do it. Lived with the old panel for about 4 months before deciding to handle it. I found the control panel on line for $146. Appliance repair shops quoted $300 and more to do it - telling me the part itself would cost $275. Save yourself some money and the installation was very easy.
Apr 19, 2008 | Jenn-Air JJW8630C Expressions Collection...
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
