Question about Pioneer DEQ-7600 15-Band Car Equalizer
No sound. I hooked up my DEQ-7600 correctly. All lights work, and controls look to be operating correctly, but no sound output. Tried various input signals - walkman, mp3, old stereo receiver, etc, but no output. Tried running it from a radio shack 12-volt power supply also, but still no audio output at all. Unit looks to be in good condition. Took the cover off, no fuses inside. Is it feasible/worthwhile to have repaired? Any recommendations for repair shops?
  • stevo442 Oct 12, 2008
    i have a deq 7600 pioneer and i get lights but no display or soung can anyone help?
I have a boss audio equalizer and the out put channles wont play
Posted on Aug 07, 2009
If you have not solved the issue yet here is what I ran into. I bought one off craigslist. I found that the conventional Line Level outputs are very low compared to that from a reciever unit. If you have the blue and yellow wires tied together and the unit is connect to PRE AMP outputs then it should work. It will not work with the head phone level from any mp3 player.
Posted on May 23, 2009
  • 25 Answers
As you have indicated there is no sound at all in the out-puts available.What this could probably mean the out put ic is dead.Another thing to remember is to connect the red positive wire to the standby wire which is mostly yellow in color.
Posted on Aug 27, 2008
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
Jun 02, 2016 | Tascam Computers & Internet
Maudio 192 output
You need the plug/cable that inputs to your mixing desk and outputs from your sound card.
Sep 09, 2008 | M-Audio Audiophile 192 Sound Card
How do i turn off the dsp and run stereo mode?
Pressing the PROCESS button opens up the various screens that determine the signal path setup and that control processing parameters for the DSP modules: I/O, PEQ, XOVER, DEQ, DELAY, and LIMIT.
I/O
The I/O module sets up the signal routing inside the DSP from input to output. Press and rotate the SELECT encoder knob to choose between dual mono, stereo, bi-amped, or bridged routing options.
STEREO
STEREO mode routes the signal from both the A and B inputs through a single series of DSP modules. The parallel DSP modules process the A and B signals with identical, linked settings (only module "A" parameter settings appear on subsequent DSP module screens).
The manual is available at: http://www.behringer.com/assets/NU6000DSP_NU3000DSP_NU1000DSP_M_EN.pdf
Jun 02, 2014 | Behringer Inuke Nu6000dsp 6000-watt Power...
I have a Pioneer DEQ-7600 and every so often I have to tap my dash board in order for the display lights to come on the front of the unit, like it goes in and out every so often, thanks Nick
Nick i believe that you have a simple ground loop problem. To fix that you'll need to run a ground wire from your EQ to the body of the car. (the shorter the wire,the better the ground)
Find the ground wire (black wire) coming out of your EQ. Splice a wire into that wire,and then connect that wire to the black wire coming out of your Head Unit,and that should solve your problem.
Feb 11, 2011 | Pioneer DEQ-7600 15-Band Car Equalizer
My pioneer deq 7600 keep resetting it wont memory
do you have the yellow wire going to a constant power source??
Sep 24, 2010 | Pioneer DEQ-7600 15-Band Car Equalizer
What is Monitor Out on 42'' Hitachi plasma TV (42HDT50)
Monitor Out connects audio and video signals to an external monitor with corresponding inputs as noted in the document.
Mar 07, 2017 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
Sep 06, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
How to change the color display and brighten it up for a Pioneer deq-7600?
Here's a link to the manual in english...
http://akamaipix.crutchfield.com/Manuals/130/130DEQ7600.PDF
I read thru it, and no mention of how to do it. I do believe it can tho.
Jun 07, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
Pioneer DEQ-7600 15-Band Car Equalizer Logo
489 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
