Question about Dometic WA3210 Compact Refrigerator
Model rm 46 won't work on 120...fine on propane..seems to lose power in the circuit board on the back. not sure how to check where power is lost...maybe thermostat?? or heater???was lookin for a wiring diagram when i found this page...it did work last summer but quit half way through...
    Top Expert:
  • Dometic Master
  • 6,465 Answers
Bad heater element
Posted on Oct 06, 2017
4 Suggested Answers
  • 68 Answers
SOURCE: My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Posted on Mar 19, 2009
  • 20 Answers
Between 1993-1996 dometic used a yellow epoxy filled circuit board that went bad pretty quickly if you have the yellow filled circuit board rather than the green one it is most likely the circuit board
Posted on Feb 20, 2009
  • 5370 Answers
SOURCE: Our RM 2852 works fine
The heat is not as per required or problem with burner or burner orifice is clogged or cracked.Or propane is leaking or propane pressure is low. ------------- Click this link and follow the troubleshooting to get the exact problem confirmed :--- http://howtobyme.blogspot.com/2011/08/dometic-rm2852-not-working-on-propane.html ----------- This will help.Thanks.Helpmech.
Posted on Aug 29, 2011
Hi, I have sound but no video. Do I need main board replacement part eax61746403 or video board ebu60852909?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 12, 2016 | LG 46LD550 46-Inch 1080p 120 Hz LCD Hdtv...
I have a tv that the screen goes from very dark to black. Sometimes the screen will come back on sometimes not. Everything else works fine. Can you please assist me with what the problem would be?
Sep 23, 2015 | Vizio 46" Class Theater 3D Edge Lit Razor...
RM 2611
maybe bad 120 volt side of board that is bypassing thermistor
Apr 17, 2014 | Dometic Refrigerators
TV won't turn on. For a short time, it was on then went off now we can't get it back on....
the problem was there's a cold solder on the power supply or in the raster circuit. Look for lose contact in the PCB board it might gonna work or check your plug might lose wiring. You need soldering to do this job.
Sep 20, 2011 | Mitsubishi VS-45609 TV
I have an intertherm furnace. It was working fine on saturday night. tried to turn it on sunday night it won't do anything. The led status light is off. Checked breakers, all good. tested the power...
Hello, test for 24 volts between r and c terminals and for 120 volts at L1 and neutal on the control board, if ther is voltage to the board then the control board is faulty and must be replaced.
Sep 06, 2011 | Intertherm P3RA-048K Air Conditioner
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Feb 03, 2009 | Dometic RM2652 Refrigerator
Jan 09, 2009 | Dometic RM2652 Refrigerator
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Dometic WA3210 Compact Refrigerator Logo
96 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
