Question about HP Compaq dc5100 Small Form Factor PC Desktop
I was playing around in my bios and must have set something wrong because no I get the black screen with F9, F10,F12 at the bottom right (Boot, Setup, Network) but not the blue F! at the left to boot it up. I can't get past this screen. How can I reset the bios since I can't even access it anymore?
  • 917 Answers
Unplug the PC from the mains power socket. Open the case. Look carefully inside at the main board. There should be a small 3V button cell in a socket. This maintains the CMOS data configured in the BIOS setup. Remove the battery and leave it out for a few minutes. Re-insert the battery, close the cover and re-connect the power. Switch the PC on and you should hopefully be able to get into the bios.
Posted on May 19, 2011
    Guru:
  • 666 Answers
Just set the BIOS configuration to its default settings. Simply access the BIOS again and on the BIOS, Press F9 and select "Yes or press Y" to load BIOS defaults and Press F10 to Save and Exit BIOS setup.
Thank you for visiting FixYa!
I have an HP Mini 110-3135DX. When I turn on the power all that is displayed is a blue screen and it wont boot. How do i fix it?
check you bios pages are correctly configured,,goto bios navigate with "tab" and arrow keys,,play around untill you know these pages dont change anything untill you are sure you know what you are doing..Exit and save pay attention to boot sequence if this is set up wrong it might cause failure in the way you describe,the instructions on the right hand side of the bios pages should help you---good luck --Davey
Jun 20, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Linux mint 12 won't boot from CD
Restart your computer, press repetedly a key to enter BIOS, normally Del, go to Advanced BIOS Features probably and change to boot primarly from CD/DVD (1st Boot Device CD/DVD , or something like that), save and exit BIOS, and restart your computer with Linux Mint CD inside. Be aware that if you make wrong changes in BIOS, you could damage your computer.
Feb 18, 2012 | Acer TravelMate 4001LCi Notebook
Which button do i press to get into the boot menu of the asus a54f
Common keys for boot menu, BIOS and/or recovery are F1,F2 F9-F12 or del. It should list which is for what on your specific computer as it boots. Boot Menu is usually F9 or F10
Jan 07, 2012 | ASUS A52F-XE2 Notebook
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
How do I install Windows 7 etc on new Asus 5X DC
get the windows 7 cd, put it in the DVD drive, watch for boot options when the computer starts something like "press F9" for boot options. Its typically (F9-F10 or F12) select boot from CD Follow the prompts. If you cannot locate the boot options. Go into System Setup at boot and change the BIOS Boot order, To CD first then hard disk. Cheers
Aug 25, 2010 | ASUS Computers & Internet
HP Omnibook xe4500 on boot up says PXE-E61 Cable missing; Operating System Not Found. Wha do i do?
hi,
Selecting and un-selecting drives in BIOS can be a tricky process...let's try this: a) Step 1: go into BIOS, select F9 ( restore defaults) then F10 (save and exit). Re-boot. b) Step 2: back into BIOS, go into "startup" then into "boot" and choose "diagnostics". F10 to save and exit. Re-boot. You should be able to see both your drives (DVD and HDD) while "diagnostics" runs its course during boot. If you have a drive missing, there's your problem. If you don't have a drive missing, back to the previous idea: press F12, choose to boot from CD-ROM and see what happens this time around. Good luck and let us know. Install a fresh copy of windows xp. Thank you.........
Sep 14, 2008 | Computers & Internet
Hp pVILLION DV 1000
This error message may appear when the computer BIOS is set to boot from a network and cannot find a bootable operating system on the network or on any of the storage devices included in the notebook PC's boot path.
The following steps are for most HP Pavilion and Compaq Presario Notebook PCs. The boot order can be configured on the Advanced tab in the BIOS settings menu. The steps to modify the boot order may vary depending on the model of your computer. On most HP notebooks the boot order can be configured using the following steps:
  1. Turn on or restart the computer.
  2. While the display is blank, press the F10 key to enter the BIOS settings menu. NOTE: Some notebook PCs use the F2 or F6 key.
  3. Use the right and left arrow keys to select the Advanced tab.
  4. Use the up and down arrow keys to select Boot Order .
  5. Follow the on-screen instructions to change the boot order.
Reset the boot order to the default settings Use the following steps to reset the boot order to the default settings:
  3. Press the F9 key to reset the BIOS to default settings.
  4. Press the F10 to save the changes and exit the BIOS settings menu.
I think it will you to fix your problem.
If still have problem then tell me more about it.
Thanks
Iqbal
Mar 18, 2008 | HP Pavilion Elite M9060N PC Desktop
Changing Sony Vaio BIOS
you should be able to exit and save changes, which my guess is you are exiting without saving the changes. theres is a way around this, by pressing either F8, F9, F10, or F12 to access the boot menu, and then you can boot from cd to install your linux operating system
Jan 09, 2008 | Sony VAIO PCV-RX511 PC Desktop
HP Compaq dc5100 Small Form Factor PC Desktop Logo
293 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
