Question about Fisher and Paykel CT560QX 23 in. Electric Cooktop
Turn burner elements on.any of them,and they only work on hi.no adj on any of them
  • 1,998 Answers
First question is the unit new? if the top burner elements are all only running on hi this would tend to be a control issue where as being a switch issue which i think would either affect one or one side of the burners but your stating that all burners are only working on hi which would lead me to think that your having a control board issue with your unit. If you have a multimeter you can check this by testing that the voltage is going to the control board and then to the switch and when the switch is set to low if there is still voltage going to the switch. If you have any further questions message me back I await your reply Thanks Rick
Posted on May 19, 2011
One of the burners will not work
Heating element might be not working in your stove.
Jan 15, 2013 | Maytag MEC5430 Electric Cooktop
One large burner element does not work, can the element be replaced? Price of replacement element? Thanks
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jul 02, 2010 | Frigidaire FEC32S6 Electric Cooktop
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Left burner is not working
these elements merely unplug when you lift up the one side of the element,then just easily rock back and forth till it unplugs from the stove top
Apr 25, 2010 | Kenmore 30 in.44084 / 44089 Electric...
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
Smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Sep 30, 2008 | Frigidaire 31 in. GLEC30S9E Electric...
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
Fisher and Paykel CT560QX 23 in. Electric Cooktop Logo
104 people viewed this question
Top Fisher and Paykel Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
