Question about Panasonic FH20 Digital Camera
I get a zoom error message when i try to zoom in or out. then the camera shuts off and says to turn camera on again. help.
  • Panasonic Master
  • 43,501 Answers
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Posted on May 19, 2011
I turned on my camera and I get an error message that says, Lens Error Camera will shut off automatically. Then the camera shuts off. The lens will not pop out?
Hi.
This problem occurs when there is zoom-block problem. The solution is to change all the zoom-block, but normally this is more expensive than a new camera.
This mechanism fails due to sand, dust or just useful life expired.
Aug 27, 2015 | Canon PowerShot A4000 IS Silver 16MP...
Zoom in/out power off message
While zooming in-out camera gives error message means lens mechanism is either defective or lens drive motor is bad. In both cases, lens assembly will be replaced.
Contact nearest camera repair shop for fix.
Thanks.
Sep 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
The lense will not zoom
Your camera has a zoom failure that can not reset by pushing menu buttons or else. Ask your local Sony repaircenter.
Regards,
Rob NL
Apr 24, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
The camera says please turn camera off and then on again every time i turn it on
while you are turning the camera on, hold the lewer which you use for zooming in. the lens should extend before you get the annoying message about turning the the cameroa off and on. then, GENTLY apply pressure to the lens as if you wanted to push it back to the camera. while you are doing this, turn the camera off (lens should come back into the body of the camera). this solved the problem for me! :D
Jul 12, 2008 | Panasonic Cameras
IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Jun 05, 2008 | Olympus i:robe IR-300 Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Problem
I had the same problem and fixed it.
The problem is related to the lens not working properly and jammed up.
When powering on the camera, the focus goes in and out and the lens spin and then the message is displayed to turn camera off.When I turn the camera off, I noticed the lens did not fully hiberate into the camera like it did before the error message.
So to fix the problem I did the following:
Turn the camera on, when the lens extended out, I slightly rotated the outer most lens clockwise and counterclockwise to free the lens from the jammed position.
The error no longer appeared and the camera stayed-on.When I shut the power-off the lens completely hibernated again like normal.
Hope this helps.
Pete
Dec 25, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
I have a finePix 3800 Zoom error : wont correct itself
I guess something has stalled the zoom motor Check out Fuji support for advice - but I guess you will not like the answer.
Sep 14, 2007 | Fuji FinePix S3000 Digital Camera
Panasonic FH20 Digital Camera Logo
93 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
