Question about Sewing Machines
I have a Viking Vanessa Model 5610, It is small and light-weight, it servse me well. I have a problem, the upper thead can not catch the lower thead. How can I resolve this problem. Thank you for your time!
4 Suggested Answers
  • 1116 Answers
SOURCE: Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Posted on Mar 03, 2010
  • 1116 Answers
SOURCE: The upper thread no longer catches the lower thread
Check the needle to be sure it is installed per the manual.
This is usually with the flat side of the shank facing the back of the sewing machine.
Last resort - take the machine in for service as it could be the timing needs to be adjusted.
Posted on Apr 01, 2010
  • 1788 Answers
SOURCE: Hi please help. I have a
Years ago I had a machine that did that, and I was told to take a hair dryer to the machine after I took off the outer case. Work your stitch length and reverse lever until it frees up. Put your stitch length at its highest first and see it it does anything. I don't know if this will help you or not but it sounds like my machine problem, good luck and I hope it works for you.
Posted on Sep 19, 2010
Bobbin thread picks up when there is no fabric in machine,as soon as i put fabric under the foot it skips stitches or doesn't catch at all. have changed needles, re threaded and adjusted timing.
I have run into this problem on newer light weight machines.
Remove the nose cover and look for thread wrap in the upper tension control, even a small piece of fluff can keep the discs from closing when you drop the presser foot.
Try not to disassemble the upper tension control because they can be tricky to get back together.
Check around the slack arm, thread will wrap-up at the pivot.
Good luck.
Feb 18, 2016 | Singer 2639
Why isn't the upper looper of my Simplicity Easylock looping?
The thread probably had not gone through the threading eye of the upper looper.
May 02, 2015 | Simplicity Sewing Machines
THE CLOTH WILL NOT FEED ON MY MACHINE IF I USE ANY STITCH BUT A STRAIGHT STITCH.
it sounds like the machine needs to be checked to see if there is a problem with a part inside the machine
Nov 30, 2014 | Husqvarna Viking Emerald 116 Sewing...
How do I find a foot pedal for a Viking Vanessa model 5610 with a power cord?
The part is no longer available from Viking. However, you might be able to buy a used one on ebay or from sewing machine parts. However, you might try contacting some of the Viking stores to determine if they have a used one from a machine they use for parts. You can send me a private email and I'll give you some Viking dealers you can contact. email: deborahcha@aol.com
Oct 15, 2014 | Husqvarna Viking 1
Upper thead will not catch bobbin thead
try a new needle--make sure the needle is the correct one for the fabric
being sewed
try rethreading the machine top and bobbin
make sure to use every thread guide
try a different bobbin--make sure the bobbin is turned the correct way
in the bobbin case
if the suggestion don't help then the machine may need to be checked for a timing problem
Dec 20, 2012 | Sewing Machines
Model # 64 60 viking sewing machine looking for manual for sewing leather or canvas which cam to use in it
As to your question about leather, the 6460 has a special stitch for sewing leather. Select Colormatic cam C and install in the cam hole at the back of the machine. To remove/add a cam turn the upper left hand dial on the front of the machine to the small dot. This disengages the cam. Gently remove the cam by pulling straight out from the back of the machine. Install cam C straight in, ever so slightly twisting it back and forth into the hole to find the sweet spot. You'll hear a click when it's all the way in.
To use Viking's leather stitch, turn the upper left dial to the color yellow. (Note: The slash line on the upper left dial is a stop. You can't turn past that point. Go in the other direction to get to the icon or color you want.) Turn the upper right and bottom right dial to yellow also. The upper left dial is what selects the particular stitch on the cam, the leather stitch in this case. The upper right dial selects stitch length, and the lower right dial selects stitch width. You can move the right dials within the color range. Experiment on a scrap of cloth to get the stitch size the way you want it. The leather stitch looks like a straight stitch with a block style edging to the right of the straight stitch. This is supposed to give a stronger stitch to the leather rather than a straight stitch by itself.
If you don't have the manual for your machine: Select which of the eight cams you want to use. All the cams are removed/installed by turning the upper left dial on machine front to the small dot. At the rear of the machine, pull/insert cam straight in or out and twist slightly as you push in or remove to find the sweet spot. Move the dial away from the small dot to lock the cam in.
Turn upper left dial to stitch type you want and match the other dials to that same color. Upper right controls stitch length, lower right controls width. Bobbin tension is controlled by the dial at front left of the machine, above the needle.
Cams A-C are the workhorse cams and the rest are embroidery stitches.Straight stitch, button and stitched zig-zag will work on any cam. These stitches do not rely on matching a color code. To use those three: To select straight stitch, on the upper left dial, choose the icon that looks like a buttonhole with a zig that trails off to the right. Select stitch length on upper right dial and turn the lower right dial to zero, going by number rather than color.
To select stitched zig zag, turn upper left dial to the broken zig zag icon (to the right of the straight stitch icon). Select stitch length and width.
To move the needle to the side for buttonhole stitching or other times when you want the needle off center, turn the upper left dial to the button icon. If stitching a button hole, set stitch length to zero and lower right dial to desired stitch width. Push in the small white button that's beneath the lower right dial in order to prevent the feed dogs from moving the fabric forward. Pushing that button in is also handy for putting cloth under the foot before sewing as it prevents snagging and is used for tacking.
Jun 06, 2011 | Husqvarna Sewing Machines
I have been sewing all day with no problems. Suddenly the needle is not picking up the bobbin thread. Why? Solution? Thanks!
the needle might be bent-roll needle on flat surface & see if it rolls correctly
if the needle is make a popping sound when it goes thur fabric the needle is blunt
check the bobbin area to see if there is lint or loose thread
check to see if the bobbin has become warped
the bobbin may not be inserted correctly in the bobbin case
check to make sure the bobbin case is inserted correctly into the machine
rethread the sewing machine in case the thread is caught somewhere
make sure there is a thread tail of 3-4 inches on both upper thead & lower thread
Sep 02, 2010 | Husqvarna Viking 1
Bobbin problem
Suspect the needle and hook timing is off causing threads not to catch to make a stitch.
Try these troubleshooting tips:
With machine off, remove the bobbin and bobbin case. Push the needle bar to the left. Lower the needle to the bobbin case and notice when the needle starts traveling upward does the tip of the hook in the bobbin area align with the eye of the needle? If it does not align, the timing is off. If it does, move on to check upper tension:
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
May 19, 2009 | Husqvarna Freesia 415
My viking serger 905 wont cut
Sometimes the blades need to be adjusted. Lower them all the way manually to the bottom. The cutters if you look on the side should meet. If they don't' meet or if there is a small space then the upper cutter needs to be lowered.
There are screws that hold this in place. You might need a man to help since the screws on my machine are very tight!
Nov 05, 2008 | Husqvarna Viking 1
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
