Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Hi, my smartpool dolphin robo doesn't move any more. It seems stuck on the ground. When I 've started to understand why, i've discovered that out of the water, the wheels turn few seconds in one way and then few second in the other ! On the floor, it doens't move at all !!! Thanks for your help
  • 640 Answers
There are two things that you can check yourself if these pool cleaners are not moving properly. First, check the impeller. Make sure that the transformer is unplugged and take the top grill off by removing the 2 screws from the top. Check for debris and remove if you see anything. Replace the grill and tighten the screws before you try the cleaner again. Also, check your front and rear wheels. Debris and leaves can get caught in the axle bearings. Make sure this is not the case. If one of these does not solve the problem, it could be your gear box and you will have to have it serviced by a professional.
Posted on May 26, 2011
What do your do to help kids
Yout question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner is "What do your do to help kids"
Really, I have no idea what do you want to ask
Reformulate your questoin.
May 04, 2015 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
My robokleen won't **** anything up, impeller not plugged or stuck, just not turning, moves just fine
i thought the problem was the grease also until i seen another sales web page decription, it said NO OIL TO LEAK OUT, so i opened it up again after it shut off every day for 10 minutes of use , but still rolled
i seen the circuit board inside the air tight pump, somehow some water must have mixed with the greased part and i dried it with a cloth put it back together and it ran for about 20 minutes, then stopped, i tightend the screws as much as i could without harming the thread holes, if you break them your out of luck, did not see any seal but im sure the factory put something to keep it water proof
Jun 11, 2012 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen pool cleaned keeps flipping upside down. happens every time, i will watch it for a few minutes then come back later to check on it and it is upside down in the pool
check to see if the fan on top moves
if its stuck , then the motor is not pumping constant
and the pump may need some kind of lube
graphite perhaps
Sep 03, 2011 | Smartpool Dolphin Robo - Kleen Above...
Turns on but won't move.
With these pool cleaners, the first thing you will want to check is for an obstruction in the drive shaft. Hair, leaves, and even cloth gets stuck sometimes and prevents movement. Make sure that you have sufficient water flow. Make sure that your impeller is not jammed. If none of these things seem to be wrong, it is probably going to be your electrical system.
Aug 28, 2010 | Smartpool Dolphin Robo - Kleen Above...
User guide for ariston washing machine cw 810
Your questions seems to be for two different products. Your picture and product description is for pool cleaners, but you mention a washing machine. I do not have info on a washing machine, but I can give you the users manual for the Dolphin robotic pool cleaner. Hope this is what you are looking for.
http://www.backyardcitypools.com/images/smartpool/robo-kleen%20-Manual.pdf
May 08, 2010 | Smartpool Dolphin Robo - Kleen Above...
Dolphin quit working
See if the Dolphin ingested acorns or leaves which may be clogging the unit.
Aug 09, 2009 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
190 people viewed this question
Top Smartpool Pool & Spa Experts
Robert Plante
Thomas Perkins
Thomas Perkins
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
