Question about Cell Phones
Tried paring my bluetooth with my new phone and now dosent work
  • 60 Answers
What is the brand of that blue tooth you are using? and what brand of phone is your new phone?
maybe the two are not compatible if they are of different brands.
Posted on May 19, 2011
I can't find the codes for bluetooth pairing.
Normally, the 'factory default' paring code for a new bluetooth device is - 0000. Try this first.
If 0000 doesn't work, then try resetting the cd player back to factory settings (contact the manufacturer for further assistance).
Nov 28, 2011 | Car Audio & Video
How do sync with my new phone?
1. You must start with the headset in the OFF position. Put the headset in pairing mode by Pressing and holding the Multi-Function Button until the lights are flashing alternating Red and Blue, you will then release the Multi-Function Button. Please note the headset will continue flashing Red and Blue until the paring cycle times out (approximately 2 minutes) or completes the paring with the cell phone. If you only press and release the Multi-Function Button the headset will not go into the paring mode.
2. Once the headset is in paring mode, go to the Bluetooth menu / connections of your cell phone. Select add new / search for / find new device (different phones have different but similar names for the options). The cell phone should find a device called VXi B250-XT. Move the cursor over the VXi B250-XT and press (OK, select, enter, or whatever your phone uses for a prompt). If the cell phone asks for a passkey code you will put in 0000 (four zero's). The headset will then pair and connect to the cell phone and be blinking Blue once every second. Your phone may ask you if you want to connect to the B250-XT and/or add it to your trusted device list, press (OK, select, enter, or whatever your phone uses for a prompt).
Aug 01, 2011 | VXI Corporation Blueparrott B250-XT...
My cell phone's bluetooth not work proparly
Maybe the problem with your connection of your bluetooth is in the pairing of the devices of the other phone that you are connecting.Try to erase some other paring devices on your phone.You can find that in the settings of the connection on your phone.After you erase some of the pairing devices on your phone kindly try to connect via bluetooth.
Jul 17, 2011 | Home
HBM 730 Bluetooth Headset Wireless Headset: what is the mfb on my bluetooth headset and do i t...
I don't know your headset in depth, but MFB stands for Multi-Function Button. Headsets usually have one big button used to make, answer, and end calls. There may be other buttons, too, like volume up and down. To turn your headset on, press and hold the MFB for some seconds, until its indicatior light flashes. To turn it off, press and hold the MFB again, until its indicator light is turned off. To put it in paring mode (starting with the headset powered off), press and hold the MFB much longer than the time required to turn it on (you'll notice that it will flash as if it was turning on, but keep pressing the button). Headsets indicate they are in pairing mode when the light either keeps flashing rapidly (sometimes in more than one color), or stays solid lit, As I've said, I don't know how yours will behave, but you will find out. Once it is in paring mode, make the bluetooth application on your phone search for new devices. After a while, the HMB-730 will appear on the phone screen. Select it and make the application proceed. If a paring code (or PIN, or passkey) is requested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 17, 2010 | LG HBM 730 Bluetooth Headset Wireless...
When i enter the passcode it tell me passcode mismatch
Have you put your heaset in paring mode prior to trying to pair it with your phone (or computer, or any other bluetooth enabled device)? If not, start with it turned off. Then, press and hold the MFB (Multi-Function Button) for some 8 seconds, until the indicator light is steadily lit. It is in pairing mode now. Make your phone's bluetooth application search for new devices. After a while, the WEP200 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is required, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Feb 15, 2010 | Samsung WEP200 Wireless Headset
How do I connect my IPOD nano to my Motorola S9 HD Headsets
I downloaded the instructions manual for the Motorola S9 HD and implemented them. It worked fine!
Jun 19, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Samsung sch-a870 cannot find samsung bluetooth wep200
Is the phone set to visable, the settings within the bluetooth are obviously turned on, but are they also set to visable, if the phone is not visable to other users, whether the bluetooth is turned on or not the other phone will not detect it.
Nov 22, 2008 | Samsung SCH-a870 Cellular Phone
HELP....
Well my user manual for HBM-550 says:
Prior to using the Headset for the first time, you must pair it with a Bluetooth enabled handset.
With the HBM-550 off, press and hold the Pwr/End button for 5 seconds,
You will hear two short beeps and the LED indicator will flicker in red and blue alternately, when the divice enters Paring Mode.
Using your Handset, find the Bluetooth Menu and "search for" or "add" new devices.
Select "LG HBM-550" from the list of devices and pair it with your handset.
When asked for the pass/PIN code during the paring procedure, please enter "0000" (4zeros).
Once paring has completed successfully, you will hear a beep.
After paring successfully, be sure to "Connect" to the HBM-550.
If you want to pair with other devices in the future, the headset must be placed in pairing Mode.
If the HBM 550 is in "Paring Mode" for 3 minutes, without being paired to a device, the Headset will automatically turn off.
Aug 13, 2008 | LG HBM-550 Wireless Headset
N72 - Not able to Connect Motorola Bluetooth Headset ( H500)
Hi
My cellphone Nokia N72 is not paring with Nokia -BH-102.
When i began to search , but it not connecting
By Vijeesh
Jun 24, 2008 | Nokia N72 Cellular Phone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
