Question about Lite On LiteOn 204Watt PA-4022-6B Power Supply (190050) Power Supply
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
  • Kjell Olsson
    Kjell Olsson Sep 04, 2013
    You mean 12VDC and 5VDC???
  • 106 Answers
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
Posted on May 19, 2011
Coleman presidential furnace
bad fan control switch or bad fan motor
Nov 28, 2017 | Coleman Heating & Cooling
Lamp never fires Unit goes right to cool/shutdown.
The ballast might have gone bad, you'll need to check the output voltage of it. In some projectors, the power supply/ballast are combined as one PCB instead of 2 separate boards.
Jul 24, 2015 | Office Equipment & Supplies
How do i know if my jazzy power charger is working
Without the charger the batteries would go dead. You could put a voltmeter across the batteries and you should read more than 28 VDC while charging.
Nov 16, 2012 | Electric Jazzy 1115 Power Wheelchair
The air comes on and blows, but the fan outside doesn't spin....tho the air feels a bit cool, the apt never cools off
hello, if the compressor is running and yet the condenser fan motor is not most likely you have a bad capacitor to the fan or if it's a dual capcitor the fan side is bad. Another possibility is the motor itself could be shot but you would need a meter to check. with the power turned off and take you meter and put one meter lead to the ( common) wire and take the other meter lead to each additional wire coming from the motor one at a time, if you dont have resistance between any of the wires then the motor has a open winding and should be replaced.
Apr 26, 2011 | Weather King 10AJA2501AH Air Conditioner
Cooling fan running slow
test the leads that attach to the fan make sure they have a secure seating and are not faulty also
the fan itself might be faulty
you might test your PSU power supply unit with a multi meter make sure its sending out the correct amount of power/wattage
Jan 12, 2011 | Gateway Computers & Internet
Fan on my big buddy heater just stopped working changed batteries still not working?tried the switch nothing .i only have radiant heat.
I would first check the wiring connections to fan and get a multi meter , set on 12 volts dc and see if fan motor has 12 vdc input voltage.
Too cheap to buy a voltage tester at wal mart ot harbor frieght, you can use a 12 volt bulb and socket, if you already have one. Remove fan wires & hook up 12 volt light bulb & if it lights, you got the juice. Carefull,dont let live wires touch because you short out $26.00 big buddy fan transformer. work with fan transformer unplugged from wall and dont plug in until you sure no wires touch.
use electrical or duct tape. electrical tape better.
otherwise,just buy the multi meter, they only $8.00 to $10.00
read & understand instructions, before you try to use it. otherwise,you could burn out your new meter.
well worth owning &
learning to use multi meter. I use it thousands of times.
if fan motor has juice but wont run, check fan shaft to see if it turns freely or scrapes or is stuck. oil fan motor bearings ,change the brushes.
make sure that the fan blades are not touching the fan housing and can turn freely.
if it still dont work, buy new fan motor.
if no juice at fan motor, check mr heater switch with the power off,unplug transformer from the wall or remove batteries.,
and use the ohm meter setting of the multi- meter to test for continuity of the switch when the switch is in the on position.
power must be off when using the ohm setting of a multimeter.
if power is on & using the ohm setting of the multi meter, you will blow out the multimeter. The ohm setting uses a 1.5 volt dc battery inside the multimeter to test for a compleated circuit.
so, 12volts dc would blow it out on ohms setting.
TESTING FOR OUTPUT OF FAN TRANSFORMER OR BATERY PACK.
If the switch is good,reinstall it on mr.heater and test the output of the transformer or battery compartment using the 20 volt dc scale of the multi meter. the voltage scale you select ,must be higher than the voltage you expect to find ,in order to avoid damage to the multi meter.
observe polarity,positive to red and negative to black.
the dc voltmeter setting is totally polarity sensitive and a reversed hook up could blow out the meter.
multi meter means it can read ac volts, dc volts,ohms and dc amps. Read and understand the included instructions before using a multi meter
a good single battery in new condition reads 1.62volts dc
1.5 vdc is almost dead, a good used battery reads 1.58 to 1.6 vdc
below 1.58 vdc is weak battery and 1.48 vdc is usually totally dead, but may be enough for momentary usage under 1 minute.
Sep 08, 2010 | Mr. Heater Big Buddy Heater
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
While running the computer all of sudden switched off
If your PC SMPS is ok then your PC motherboard has been faulty. pls checked it from service center.
Oct 13, 2009 | ASUS P5GD2 Deluxe Motherboard
What's the deal? Wont shut off or respond to thermostat. . .
Red= power........White=heat.............Green=fan.................(grey)-(yellow)=cool .....these are the connectons. Disconnect these wires from the thermostat and know that red/power is the only wire that send power to the thermostat, and the rest sends it back to the unit to call for whatever,, red--to . white for heat... red to green for fan .... &red to grey for cool! OK! Turn all your power on, and use a jumper wire from red / green for fan and see if the fan comes on! Then move the jumper wire from red to green , to red / to white for heat and the fan , wait for 3 minutes before removing and going to the next step. Then red /to grey for cool and check if the outside comes on. Either you have a wire touching past the insulations and making a connection, a bad thermostat ,oe excessive wire lead touching the next connection.Thank you very much!
Nov 05, 2008 | Intertherm Heating & Cooling
Not cooling
hi thanks for the question i would replace the fan motor in freezer thanks the appliance doc
Sep 25, 2008 | Hotpoint HSS25GFP Side by Side...
Lite On LiteOn 204Watt PA-4022-6B Power Supply (190050) Power Supply Logo
254 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
