Question about Canon PC-940 Black and White Copier
Copies come out blurry - Canon PC-940 Black and White Copier
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert
  • 259 Answers
That is mean the Hot roll or press roll doesn't work,
you must be replace a new,
Posted on May 20, 2011
Blurry copies
clean ur leser mirror&full gradiation adjust
Feb 08, 2013 | Canon imageRUNNER iR C4080 Color Copier
Why is the print blurry
If black & white copies are ok you can probably bet it is an issue with the ITB (transfer belt assy) or a color registration issue. If black & white copies are also blurry.....could be a variety of issues. If it only happens when you copy but printing is ok from the computer......scanner is at fault.
Jul 31, 2012 | Canon imageRUNNER C3200 Copier
Brand new fax when we send a fax it is received at the other end fuzzy or blurry. Tried a different phone line and still the same. Cleaned glass on scanner
Slight possibility that your sending in Photo Mode, most likely the machine was damaged during shipping and the CCD unit or scanner is out of alignment. Just make a copy....if it comes out blurry then it is the scanner. I would return it for another machine. If the copy comes out nice and clear then there is nothing wrong with the scanner.
Oct 22, 2009 | Brother IntelliFax-4100e Fax
How do i align my printer, it's printing blurry but copies fine
the problem is with the main board. I fixed two of the exact same problem before.
May 28, 2009 | Brother Multi-Function Center MFC-240C...
Scan and copy lines
using PRT screen and menu find clen function and try if this feature will fix the issuw.
Change the cartridge if no results.
Jan 30, 2009 | HP LaserJet 3050 All-In-One Printer
Blurry Copies on Xerox WorkCentre C2424
There are three typical reasons for fuzzy text
1. Y-axis drum rotation problem.
2. Wrong drum temperature.
3. X-axis movement problem.
Sometimes the y-axis encoder will get oil inside and confuse the sensors, causing fuzzy/blurry print.
Most likely the drum assembly will need replaced.
Dec 03, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Blurry Scanning/Copying
Are you scanning both black and white and color the same way? The ADF (automatic document feeder) uses a different scanning area than when you place the document on the scanning glass. If you open the scanner cover, look to the left of the main scanner glass to the narrow strip used for the ADF. Make sure this narrow strip is clean -- no ink or white-out or scratches. This can make your copies look dirty or smudged.
Jul 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Laser Printer Copies Blurry
are copies blurry? from the glass or printing? clean the glass, and optics. and the machine could probably use a calibration..
May 16, 2008 | Office Equipment & Supplies
My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Oct 31, 2007 | Office Equipment & Supplies
Canon PC-940 Black and White Copier Logo
35 people viewed this question
old marine
old marine
