Question about Samsung TruDirect SpeedPlus DVD-RAM Burner
Can you please give me a drivers for my samsung super writermaster trudirect plus. All the cables is connected and I have rebooted several times, but I still only see my C Drive, I did run driver mender, but still I could not fix it, driver mender is not picking it up. Please help I need to use my DVD/ CD romp to load some programs I bought.
  • shereeben May 21, 2011
    Hi I have tried all the above, but it did not work, you do not perhaps have the driver that I can install it. I have a disc but it is useless, both my CD/DVD drivers are not working. I uninstalled one and know I do not know how to reinstall it, there is not option for it,
  • Samsung Master
  • 27,725 Answers
You might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 20, 2011
Writer not functioning
are the cables still in the right way?
Mar 18, 2014 | Samsung Super Writemaster 20x Speed Plus...
My samsung trudirect dvd writer is not shown on mycomputer. please help me soon. thank you.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
May 06, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
I don't see my dvd-rom in my computer
if it is not detected in your system, check if the cables connecting to your dvd rom is well connected.
Feb 17, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
Samsung TruDirect SpeedPlus DVD-RAM Burner can't see any DVD/CD when BURN, but READ still good. HELP me plz
make sure all leads that are attached to your drives cd/dvd, 3 1/2 inch floppy have secure connections and are not faulty
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 07, 2011 | Samsung TruDirect SpeedPlus DVD-RAM...
I can't find my dvd driver in my computer . all i can see local disk C. no dvd drive ? what will i do ?
Ensure the cable is correctly plugged onto the motherboard, if so then try another cable (IDE / SATA) If you are sure they are good then DVD is faulty.
Oct 20, 2010 | Samsung TruDirect SpeedPlus DVD-RAM...
Super Write master Samsung TruDirect SpeedPlus
the CD ROM cannot display the content of the CD. Give me the best solution please.
My DVD Rom did not detect in CMOS setting
check cables that are connected correctrly or not.if ur drive is safe,after connecting it must detecting.try to re-install it from device manager.
Jul 09, 2010 | Samsung TruDirect SpeedPlus DVD-RAM...
NEED DRIVER samsung writemaster se-s164
the drivers of samsung writermaster can be directly downloaded from google .com just type the complete name and u will get the drivers or go to www.softwares.com
Mar 23, 2010 | Samsung Super-WriteMaster SE-S164L DVD?RW...
My sata Dvd Writer 22xsuper-writermaster SH-223 is not bootable
Try pressing F12 at splashscreen (compaq splashscreen) and it will give you bootable options. Choose DVD drive.
If that doesn't work, press F2 (bios options) and change the bootable disk drives. The DVD should be the first, followed by the hard drive and then the floppy next.
Reboot and your PC will tell you to press any key to boot from CD.
Sep 12, 2009 | Asrock K7VT4A-Pro Motherboard
On Line / Error Red light comes on.
recheck connections and shut windows down completely for 5 minutes before rebooting.... then if it still doesnt see it.. go to samsung site and download latest drivers and uninstall/reinstall with new...good luck
Dec 08, 2008 | Samsung ML2250 Laser Printer
Samsung TruDirect SpeedPlus  DVD-RAM Burner Logo
323 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
