Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
The standby red sigh flashing, but the screen is dark and no picture, just the sound
  • 5 more comments
  • ainis May 19, 2011
    the tv is sony Trinitron and the light flashing all the time
    model # KV-36FS10
    I did unplug and later pluged it in and the picture came on.....ye !!!
    forgot to count flashing times.....sorry.
    if that happens again, should I do the same ????
    thank you, thank you, thank you
    right now it's not flashing and the picture is fine.......if that will happen again I will start countig red light flashing....thank you
    right now it's not flashing, but the next time it'll happen I will count thank you
    thank you very ,very much have a nice day !!!
    just got home from work and the same problem. The red light was flashing.....non stop ??? counted till 100 and there was no pause...., so I unpluged the tv and pluged it in in 5 min......but this time - nothing happened, stayed dark ????
    what to do ?????
  • ainis May 20, 2011
    I guess it's time for new TV, I will try the unpluging, but thank you for recomendation.
    thank you
  • 10,594 Answers
How many times red light is flashing after 3 seconds long pause?
This info will help me to diagnose problem in your Sony KV-34HS420 tv as this model number shown in question headings or confirm tv model number as well.
Thanks.
Posted on May 19, 2011
  • 5 more comments
  • Shahid Electronics
    Shahid Electronics May 19, 2011
    Model number would be written on label pasted at rear of tv, this is very important info to open up related schematics of tv.
    There would be pause/ interval of 3 seconds between blinks, for example light will blink 4 times then stops for 3 seconds and again blinks 4 times. Its just an example so count how many times it blinks.
    Unplug tv from wall socket for 5 minutes, replug tv back in and turn it ON, this may solve tv problem as well.
    Yes, thats great that problem solved.
    Please count red light flashing and post it to diagnose possible cause of problem.
    You may accept solution to close question thread, have nice time.
    Thanks.
    Enjoy your tv shows.
    If that happens again, unplug/ replug to solve the issue and count red flashing before unplugging tv.
    Thanks.
    You may please accept solution now.
    Thanks.
    You too, have good day !!
    It seems problem of leaky/ weak capacitors in deflection section on main board of tv, visual check is needed to find out bad capacitors that top got pulgged/ busted or plastic cover (jacket) got shrink, replace these bad capacitors, please note that tv will take apart and good soldering skills are required to replace parts in circuit board.
    If you are not handy with electronics stuff repair and have no experience of soldering work then local tv repair shop is an option to get tv repaired.
    Since KV-36FS10 is an old model (1999) so repair cost may exceed tv worth so ask repair estimate to make any decision.
    Thanks.
    Shahid Electronics May 20, 2011
    Yes, new tv would be good decision.
    Thanks.
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
HI...WE HAVE A SONY PROJECTION TV, MODEL #KP 53 S 35, NO PICTURE NO SOUND, DARK SCREEN, JUST SMALL FLASHING RED LIGHT ON CONTROL PANEL (STANDBY LIGHT). NO POWER ON SOUND WHEN TURNED ON. TOLD WE NEED...
http://www.moduslinkptstvboards.com/search.php?search_query=A+1316+295+A&x=7&y=13
try this....may have to send board to them for repair.....good success, meder's tv service
Sep 22, 2011 | Sony KP-53S35 53" Rear Projection...
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
TV screen went black, sound ok, red light blink 5 times
Be sure its blinking 5 times, count after it cycles the first time through the red lights. If it is fact 5 times, that is a lamp driver error.More likely it cycled 4 times, which is common on this model, if that's the case, then it's the fan. Most likely the large one in the rear...It's an easy fix, just pull the back off and replace the part.
Sep 14, 2008 | Sony KDS-R50XBR1 50" HDTV
Sharp lc 20sh1e lcd tv funny picture
Do you still have this, I need a part myself and having trouble sourcing parts?
Mine immediately goes into standby mode and the screen just shows a white flash. I'm sure its just a power issue.
notallbad1@yahoo.co.uk
Nov 27, 2007 | Sharp Aqous LC-26D5U Television
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
50 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
