Question about Frigidaire FGHD2433KF Builtin Dishwasher
A part fell into my top tray,gray,plastic,9 inches long w/ a 2 inch diameter circle in the center,looks like its an arm,spinning somewhere?....did it fall from the inside "top",side,bottom??? Don,t know where to attach back?What is it,where does it go,can it just snap back ???? Thanks for any help...MODEL FGHD 2433 KFO...Serial # TH928998505....E-mail...rjhjth999@gmail.com
  • 731 Answers
Here is the exploded diagrams of your entire machine.
Locate the patr and you should be able to figure out where it goes
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FGHD2433KF0/1428/0130000?searchedModel=FGHD2433KF&blt=06
Posted on May 19, 2011
What is the area of a circle if the circumference is 2 pi inches
area formula is PI x r squared
that is 3.1417 times the radius of the circle squared
example is:- 3.1417 times 3 inches squared =3.1417 times 3x3=3.1417x9=28.279 square inches if you want to work back from a circumference measurement, the formula for circumference is 2 x PI x radius or PI x diameter
if you have a circumference of 12 inches then the dia is calculated 12 inches = dia x PI to get the diameter , divide the 12 inches by PI and that will be the diameter so that is 12 divided by 3.1417 =3.819 inches
now you can go from the first formula the radius is the diameter divided by 2 so the radius will be 3.819 divided by 2 = 1.909 inches
so applying the area formula it becomes 3.1417 times 1.909 times 1.909 =11.458 square inches
to find your answer simply substitute the dimensions in place of the example figures.in the relevant formula.
Aug 24, 2015 | Office Equipment & Supplies
How many gallons in 28" diameter by 20"
Just a little over 53.3 gallons
Mar 20, 2015 | Water Heaters
Where to install a cabin filter
under the dash on the passenger side...you may need to take out the glove box compartment to access easily. Don't force any plastic snappers or hinges. They break easily
Apr 23, 2014 | 2009 Honda Pilot
Can gain entry
use the physical key , or you are able to open the hood using a screw driver with a long shank ('~9 inch if I remember) or a quarter inch stiff steel rod of sorts. However, if you look through the upper center of the grill, locate the "bolt" that holds the safety catch. About 2 inches to the left and half inch down (as you look at it) there is a hole about quarter inch in diameter. Stick the blade of the screw driver in the hole and pry to the right (toward center of car). The latch will trip and the hood will open. Then you can get to the terminals to jumper and/or charge the battery
Feb 27, 2014 | 2011 Cadillac CTS
I want to cut a circle where the outside line is 18 inches
To get a circle with a perimeter of 18 inches, you want a diameter of about 5.73 inches (just under 5 3/4 inches) or a radius of 2.86 inches (call it 2 7/8 inches). Get a compass, set its legs 2 and 7/8 inches apart, put one end at the center, and turn.
Oct 23, 2013 | Computers & Internet
What is the clearance for rod bearings on the crank of a 98 ford f 150 4.6
General Specifications Item Specification
Displacement L (CID) 4.6 (281)
Number of Cylinders 8
Bore and Stroke mm 90.2 x 90.0
Firing Order 1-3-7-2-6-5-4-8
Oil Pressure (HOT @ 1500 rpm) kPa 138-310
Drive Belt Tension a
Cylinder Head and Valve Train
Combustion Chamber Volume cm 52?±.5
Valve Seats Width?€"Intake mm 1.9-2.1
Valve Seats Width?€"Exhaust mm 1.9-2.1
Valve Seats Angle 44.51-45.01 degrees
Valve Seats Runout (T.I.R.) Max mm 0.025
Valve Arrangement (Front-to-Rear) (Left Hand) E-I-E-I-E-I-E-I
(Right Hand)
I-E-I-E-I-E-I-E
Valve Stem to Guide Clearance?€"Intake mm (Inch) 0.020-0.069
(0.00078-0.00272)
Valve Stem to Guide Clearance?€"Exhaust mm (Inch) 0.045-0.095 (0.0018-0.0037)
Valve Head Diameter?€"Intake mm (Inch) 44.5- (1.75)
Valve Head Diameter?€"Exhaust mm (Inch) 34.0 (1.34)
Valve Head Diameter?€"Gauge Diameters mm (Inch) 42.5- and 32.0
(1.67 and 1.26)
Valve Face Runout Limit mm (Inch) 0.05 (0.002)
Valve Face Angle 45.25-45.75 degrees
Valve Stem Diameter (STD)
?€"Intake mm (Inch) 6.995-6.975 (0.275-0.2746)
Valve Stem Diameter (Std)
?€"Exhaust mm (Inch) 6.970-6.949 (0.274-0.2736)
Valve Springs?€"
Compression Pressure N @
Spec. Length?€"Intake 587.14 N @ 28.02 mm
Valve Springs?€"
Spec. Length?€"Exhaust 587.14 N @
28.02 mm
Valve Springs?€"Free
Length ( Approximate)?€"
Intake mm (Inch) 49.55 (1.951)
Length (Approximate)?€"
Exhaust mm (Inch) 49.55 (1.951)
Valve Springs?€"Installed
Pressure N @ Spec. Length
?€"Intake 244.64 N @ 40.0 mm
Valve Spring?€"Installed
?€"Exhaust 244.64 N @ 40.0 mm
?€"Service Limit 10 % Pressure Less @ 28.02 mm
?€"Out of Square Limit 2 degrees
Valve Guide Inner
Diameter mm (Inch) 7.015-7.044 (0.2761-0.2773)
Rocker Arm?€"Ratio 1.75:1
Valve Tappet?€"Diameter
(STD) mm (Inch) 16.000-15.988 (0.66-0.629)
Valve Tappet?€"Clearance
to Bore mm (Inch) 0.018-0.069
(0.00071-0.00272)
Valve Tappet?€"Service
Limit mm (Inch) 0.016 (0.00063)
Valve Tappet?€"Hydraulic
Leakdown Rate b 5-25 seconds
Valve Tappet?€"Collapsed
Valve Tappet Gap?€"
Desired mm (Inch) 0.085-0.45 (0.0033-0.0177)
Camshaft
Lobe Lift?€"Intake
mm (Inch) 6.58939 (0.2594)
Lobe Lift?€"Exhaust
Lobe Lift?€"Allowable
Lobe Lift Loss mm (Inch) 0 (0)
Theoretical Valve Lift @
Zero Lash?€"Intake
mm (Inch) 12.0 (0.472)
Zero Lash?€"Exhaust
End Play mm (Inch) 0.025-0.165
(0.00098-0.0065)
Journal to Bearing
Clearance mm (Inch) 0.025-0.076
(0.00098-0.003
Journal to Bearing
Clearance?€"Service Limit
mm (Inch) 0.021 (0.0048)
Journal Diameter (All)
mm (Inch) 26.962-26.936
(1.061-1.060)
Journal Diameter (All)?€"
Bearing Inside Diameter
(All) mm (Inch) 27.012-26.987
(1.063-1.0625)
Camshaft Runout
Cylinder Bore
Diameter?€"Surface Finish
(RMS) 0.2-0.6 Microns
Diameter?€"Out-of-Round
Limit mm (Inch) 0.015 (0.0006)
Service Limit mm (Inch) 0.020 (0.00079)
Diameter?€"Taper Service
Limit mm (Inch) 0.006 (0.00023)
Piston
Piston?€"Diameter?€"
Coded Red 1 mm (Inch) 90.177-90.197
(3.550-3.551)
Coded Blue 2 mm (Inch) 90.190-90.210
(3.5507-3.5515)
Coded Yellow 3 mm (Inch) 90.203-90.223
(3.513-3.5521)
Piston-to-Bore-Clearance
mm (Inch) -0.015 + 0.031 (0.0005-0.0012)
Pin Bore Diameter
mm (Inch) 22.0015-22.004
(0.866-0.8663)
Ring Groove Width?€"
Compression (Top)
mm (Inch) 1.520-1.550 (0.06-0.610)
Compression (Bottom)
mm (Inch) 1.520-1.530 (0.060-0.0602)
Ring Groove Width?€"Oil
Ring mm (Inch) 6.996-7.224 (0.275-0.2844)
Piston Pin?€"Length
mm (Inch) 61.93-62.05 (2.44-2.443)
Diameter mm (Inch) 21.994-21.999
(0.866-0.8661)
Pin to Piston Clearance
mm (Inch) 0.005-0.010
(0.0002-0.0004)
Pin to Rod Clearance
mm (Inch) 0.015-0.040
(0.0006-0.00157)
Piston Rings?€"Ring Gap
?€"Compression (Top)
mm (Inch) 1.0 MAX (0.0394)
Oil Ring?€"Side Clearance
mm (Inch) 1.25 MAX (0.05)
Oil Ring?€"Compression
(Top) mm (Inch) 0.040-0.090
(0.0016-0.0031)
(Top) mm (Inch) 0.030-0.080
(0.0012-0.00031)
Oil Ring Snug Fit
Oil Ring?€"Service Limit
mm (Inch) 0.015 MAX (0.0006)
Ring Gap?€"Compression
(Top) mm (Inch) 0.23-0.49
(0.01-0.02)
(Bottom) mm (Inch) 0.23-0.49
(0.01-0.02)
Ring Gap?€"Oil Ring (Steel
Rail) mm (Inch) 0.05-0.66 (0.006-0.026)
Lubrication System
Oil Capacity?€"Automatic
Transmission (Quarts U.S.) 6.675?±0.125
Oil Capacity?€"Manual
Transmission (Quarts U.S.) 6.425?±0.125
Cylinder Block
Main Bearing Bore
Diameter mm (Inch) 72.401-72.422 (2.85-2.851)
Crankshaft and Flywheel
Main Bearing Journal
Diameter mm (Inch) 67.483-67-503 (2.65-2.657)
Connecting Rod Journal?€"
Diameter mm (Inch) 52.988-53.003
(2.0861-2.0867)
Crankshaft Free End Play
mm (Inch) 0.130-0.301 (0.0051-0.012)
Crankshaft Runout to Rear
Face of Block mm (Inch) 0.050 MAX (0.002)
Connecting Rod Bearings
Clearance to Crankshaft?€"
Desired mm (Inch) 0.027-0.069 (0.001-0.0027)
Allowable mm (Inch) 0.027-0/069 (0.001-0.0027)
Bearing Wall Thickness
(STD) mm (Inch) 2.44-2.452 (0.096-0.0965)
Main Bearings
Desired mm (Inch) 0027-0.065
(0.0011-0.0026)
Allowable mm (Inch) 0.027-0.065
(0.0011-0.0026)
(STD) mm (Inch) 1.920-1.928 (0.075-0.076)
Connecting Rod, Piston and Rings
Connecting Rod?€"Piston
Pin Bore Diameter
mm (Inch) 21.959-21.979
(0.864-0.865)
Connecting Rod?€"
Crankshaft Bearing Bore
Diameter mm (Inch) 56.756-56.876 (2.234-2.24)
Connecting Rod?€"Length
(Center-to-Center)
mm (Inch) 150.7 (5.93)
Alignment (Bore-to-Bore
Max. Diff.) c ?€"Twist
mm (Inch) 0.050 per 25 (0.0015-0.984)
Max. Diff.)?€"Bend
mm (Inch) 0.038 per 25 (0.0015-0.984)
Side Clearance (Assembled
to Crank)?€"Standard
mm (Inch) 0.015-0.45 (0.0006-0.0177)
to Crank)?€"Service Limit
mm (Inch) 0.05 MAX (0.02)
Crankshaft Main Bearing
Journal Taper mm (Inch) 0.020 (0.0007)
Journal Runout mm (Inch) 0.05 (0.002)
Crankshaft Connecting Rod
Journal Taper mm (Inch) 0.015 (0.0006)
Feb 15, 2011 | 1998 Ford F150 Regular Cab
How to get to blub on sony KDF 42we655
I have a Sony 42 inch Grand Wega KDF-E42A10. The screen has a yellow tint and a 6 inch diameter faint yellow circle around the center of the screen. How do I fix it?
Apr 27, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The top water spinner arm fell off, how to get it
This just happened to me. The spinner arm fell off. It left behind two pieces of plastic attached to the roof of the machine: a grey sunburst shape, and within that, a white circle with two prongs. It looks like the spinner arm should snap onto the white circle with prongs . . . but you can't just press it back on, because there is no resistance on the other side and the white circle just becomes displaced instead of snapping together.
But the good news is that the grey sunburst screws on and off! Unscrew it until it comes free from the roof of your machine. Now snap the white circle and the spinner arm together, with the grey sunburst between them. Give it a test spin to make sure it's all together and working, and then screw the whole assembly back onto the roof of your dishwasher.
Apologies for the lack of pictures . . . this must sound crazy to anyone who's not looking at what I'm looking at--but it worked!
Feb 25, 2010 | Frigidaire PLD2855RFC Dishwasher
I want to remove the composite rear bumper from my 2004 nissan
Push clips, or used to refer to them as christmas tree clips. Try getting a pair of side cutters under it but don't squeeze too much on handle or you'll cut the head off, but if you do, any parts store has more. Then pry up & out with side cutters. Parts stores also have a tool specifically for them, shaped like a fork with 2 prongs.
Aug 20, 2009 | 1987 Ford F 150
LG wd8013F bowl support plastic pin fell out. I turned machine upside-down, replaced plastic pin, now doesnt wash or spin.
(A) Set-up
1) The inner bowl is supported by (2) heavy springs at the top, plus (2) telescopic shock absorbers beneath the bowl.
(B) Observed Problem
1) Inner bowl was missaligned, causing out of balance knocking & banging, also drive belt was squealing from misalignment.
(C) Remedy:
1) Disconnect power from outlet.
2) Remove (4) screws from back plate, remove back plate.
3) Bowl is suspended on (2) heavy springs from top, and (2) telescopic shock absorbers below bowl.
4) Inspection showed plastic pin retaining shock absorber end to frame had fallen out.
5) Place old carpet or whatever on floor, invert washing machine.
6) Re-align end of shock absorber into housing piece.
7) Re-insert plastic pin (about 2 inches long x 1/2 inch diameter) securely into place.
8) Re-assemble.
Also:
a) It could be one of the top springs as per (B)1 above may have broken or become loose.
b) In this case the top cover plate is easily removed from machine by removing (2) screws at the rear top of cover.
This gives access to the (2) heavy springs, which are easily repaired.
Note:
Sometimes the machine will not re-start again following out of balance problems.
1) Turn power off again, re-boot like computer.
2) There is also a re-boot procedure similar to Alt+Ctrl+Del on computer.
3) Use three buttons simulateously, Start+spin+option buttons or similar.
4) I fiddled with these until all lights lit up, then after a while the machine worked satsifactorily.
Cheers
Nov 06, 2008 | LG Washing Machines
Frigidaire FGHD2433KF Builtin Dishwasher Logo
139 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
